Will a 1987 KZ1000P stator fit on 1982 KZ1000 LTD
  • 9am53
  • 9am53's Avatar Topic Author
  • homebrew, and some bbq
19 May 2009 08:17
#292619
I have a chance to buy a stator for my 82 1000 ltd, and am pretty sure the stator from a police model 1987 kz1000 will fit, but would like to make sure before I buy. Also, is there anything wrongh with siliconing the case back on instead of buying a new gasket?
Thanks for the help?
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
Re: Will a 1987 KZ1000P stator fit on 1982 KZ1000 LTD
19 May 2009 08:31
#292623
According to Mother Kawasaki, the last year that the stator part numbers are the same (between KZ1000-K and KZ1000-Police) is 1986 (KZ1000-P5). Something changed in 1987.
Silicone will work, but gaskets and sealant is better.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
  • 9am53
19 May 2009 08:36
#292625
Thanks for the stator info...
regarding the gasket...I didnt realize you needed sealant too, I thought you just needed to clean the mating surfaces well, and the gasket did the rest :unsure:
If I do end up using silicone, is there a certain kind I should use that's specific for use as a gasket replacement?
Thanks for the help!
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
19 May 2009 09:10
#292630
I don't use a sealant on every gasket, only on certain ones...e.g. base gasket, clutch cover, stator cover, etc. I use ThreeBond products (1194 and 1211), both sold by Z1Enterprises.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
  • 9am53
19 May 2009 09:14
#292632
thanks
