- Thank you received: 540
Re-Wiring Plugs Under Side Cover
- DoubleDub
- Visitor
18 May 2009 11:13 #292424
by DoubleDub
Re-Wiring Plugs Under Side Cover was created by DoubleDub
Does anyone know which of these plugs offered by Z1E (if any) matches the stock plugs that are under the side cover? I need to completely redo the plugs as the wire shielding has broken on many and the wires are starting to fray.
www.z1enterprises.com/catalog.aspx?pid=KZ900-A4-1976-EL0
They are listed on page 4 and 5 of the link.
Thanks!
Thanks!
- MFolks
18 May 2009 11:20 #292425
by MFolks
Replied by MFolks on topic Re-Wiring Plugs Under Side Cover
If Z1 does not have what might match up to the connectors, try these two places:
1. www.easternbeaver.com
2. www.vintageconnections.com
With the correct electrical contact removal tool, most contacts can be removed,heatshrink tubing to cover the damaged wire used or new wires installed and the connector re-used.
- Link14
- Thank you received: 6
18 May 2009 11:24 #292428
by Link14
Replied by Link14 on topic Re-Wiring Plugs Under Side Cover
Hmmm, I'll have to check this evening when I get back home, I think the electrics didn't change between the '76 A4 and B1 that I have.
Like you signature, my exact situation.
- DoubleDub
- Visitor
19 May 2009 08:02 #292612
by DoubleDub
Replied by DoubleDub on topic Re-Wiring Plugs Under Side Cover
I didn't think of removing them intact. I'll have to see if that looks viable in the state they are in.
- Royal1MC
- Is it just me, or is it just great to be on a KZ
19 May 2009 09:33 #292639
by Royal1MC
*1980 Z1-R (current))
*1978 KZ1000 LTD w/ Z1-R frnt end (sold)
*1977 KZ650 B1 (sold)
Los Angeles, CA
Replied by Royal1MC on topic Re-Wiring Plugs Under Side Cover
You should have a green plug to use the combo unit.
www.z1enterprises.com/detail.aspx?ID=1873
If not sure contact either Jeff or Steve @ Z1E, they reply fairly quickly.
Los Angeles, CA
- DoubleDub
- Visitor
19 May 2009 09:42 #292644
by DoubleDub
It's more than just the rectifier/regulator that I need to rewire. There are a total of three plugs that connect to that panel and all of them need to be cleaned up.
