79' KZ1000E1/ST Replacement Coils
- lg_rebel
17 May 2009 17:42 #292017
by lg_rebel
79' KZ1000E1/ST Replacement Coils was created by lg_rebel
Hey everyone, I'm trying to replace the stock coils on my bike, but after reading some posts on here I'm a little leary of ordering them just yet. My manual says that the primary side on my stock coils should test about 1.5 ohms since it is a transistorized model. I am thinking of ordering the 1.5 ohm dyna coils from z1, but I've read that too low of a coil resistance can lead to problems with the igniter whereas a slightly higher resistance does not have much effect. So my question is should I go with the 1.5 ohm coils or should I step up and use the 2.2 ohm coils just to be safe? Also, are the copper core wires ok to use or should I be using the suppresion wires? Thanks in advance for your info.
- gane
- Thank you received: 1
17 May 2009 18:20 #292105
by gane
[img][/img] 1977 KZ1000A1
Replied by gane on topic 79' KZ1000E1/ST Replacement Coils
Personal preference, go with 1.5 coils, solid core wires, resistance caps. Package will be closest to stock pick-up/ecm requirements. luck G
- loudhvx
- Thank you received: 1616
17 May 2009 20:55 #292234
by loudhvx
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Replied by loudhvx on topic 79' KZ1000E1/ST Replacement Coils
If I'm not mistaken, the 1.5-ohm coils were meant to be used with a ballast resistor on the early transistorized models. Later (like a year later), they eliminated the resistor and went to 2.4-ohm coils. (They may have been 2.2-ohm coils, but I've never come across any less than about 2.4 ohms.)
You can use the 1.5-ohm coils if you want to maintain the ballast resistor, but the resistor wastes power. It would be more efficient to use the 2.2-ohm coils without a ballast resistor.
I would not recommend using 1.5-ohm coils without the ballast. It may burn out the ignitor.
1981 KZ550 D1 gpz.
Other links.
- lg_rebel
17 May 2009 22:36 #292323
by lg_rebel
Replied by lg_rebel on topic 79' KZ1000E1/ST Replacement Coils
Thanks for the feedback guys. After looking at the z1 website, I have decided to go with the 3 ohm coils and remove the ballast resistor. The z1 website states "For some Kawasaki bikes with a resistor in the circuit (i.e. KZ1000's in the late 70's and early 80's), the 3 ohm coil is the best choice - just remove the ballast resistor from the circuit." This made sense when I thought about it: 1.7 ohms for the resistor plus 1.5 ohms in the coil equals 3.2 ohms total. The resistances should add together since the components are wired in series. Anyway, I've ordered the 3 ohm coils, so we'll see what happens. Thanks again for the help.
- loudhvx
18 May 2009 08:41 #292399
by loudhvx
1981 KZ550 D1 gpz.
Other links.
I also use 3-ohm coils with the stock electronic ignition.
1981 KZ550 D1 gpz.
Other links.
- KZ_Rage
- Kentucky Bourbon Barrel Ale
- Thank you received: 19
21 May 2009 20:25 #293198
by KZ_Rage
1979 KZ1000E1 SOLD!
1984 KZ550F2 SOLD!
2006 ZG1000A6F (Totaled)
2001 ZRX1200R (Sold)
Replied by KZ_Rage on topic 79' KZ1000E1/ST Replacement Coils
That's a good decision as the ballasts are almost always suspect after this many years. I'm running that on my E1 for about 2k miles with no problems.
1979 KZ1000E1 SOLD!
1984 KZ550F2 SOLD!
- Bullitt03737
30 May 2009 08:04 #295011
by Bullitt03737
1980 CSR 1000. New dyna Coils, Vacumn Less Petcock, Various Handle bars depending on the day, (Drag and Clubman.)
Replied by Bullitt03737 on topic 79' KZ1000E1/ST Replacement Coils
How do you rewire the ballast after you remove it? Do I just crimp all the wires together?
- bountyhunter
- Thank you received: 337
30 May 2009 14:01 #295085
by bountyhunter
Replied by bountyhunter on topic 79' KZ1000E1/ST Replacement Coils
Bullitt03737 wrote:
That should be correct, you want to bypass the ballast resistor if you go to a higher resistance coil.How do you rewire the ballast after you remove it? Do I just crimp all the wires together?
