where to start
- latherface
where to start
15 May 2009 19:19 - 15 May 2009 19:49
have a kz1300 with all the fairing and bags (which i want to dump) and was wondering if i can hot wire it to see if it is getting spark by by passing all other switches etc, as a starting point, and if if it is possible to retrofit the ignition to a points system? i like simplicity
Last edit: 15 May 2009 19:49 by latherface. Reason: new info
- franknsr
Re: where to start
15 May 2009 20:46
I *think* you can do this by getting power to the coils. Not absolutely sure because my manual is for a 650.
It’s fairly easy to check for power at the coils and trace the wires back checking for voltage back to the solenoid. Do you have a manual with a wiring diagram?
Just sharing an opinion here but if you want simplicity you might want to stick with the stock electrical system.
Formerly CSRchopper
1991 KZ1000P
Gone but not forgotten
1986 ZG1000
1982 650 CSR -shoulda kept this one-
Lisle Illinois, USA
1991 KZ1000P
1986 ZG1000
Lisle Illinois, USA
- StreetfighterKz
Re: where to start
16 May 2009 12:40
latherface wrote:
Do you have a 1980 Touring model? If you do, keep the fairing and saddlebags as Kawasaki only made the B-model that year only and body parts are hard to find if you want to go back to stock for whatever reason. Good luck with your project!
Later, Doug
Later, Doug
1978 z1000 Streetfighter
1976 z900 ‘Stripfighter
1978 z1000 w/RC Turbo
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
1979 z650 Resto-Mod
2018 Z900RS
- latherface
Re: where to start
16 May 2009 15:30
yup manufactured march of 1980......how many were made. seems now like it would be better to leave it stock. if #'s manufactured were small. where can I find info on production numbers?
- MFolks
Re: where to start
16 May 2009 20:05
Have you looked at:http://www.motoverse.com/tools/vin/kawasaki.asp
and www.z1enterprises.com Jeff Saunders at Z1 is very knowledgeable about most things Kawasaki.
- franknsr
Re: where to start
17 May 2009 18:27
You can also get some more info at
www.kz1300.com/techarticles/z1300-model-comparison.html
No production numbers though.
Formerly CSRchopper
1991 KZ1000P
1986 ZG1000
Lisle Illinois, USA
1991 KZ1000P
1986 ZG1000
Lisle Illinois, USA
