Starter Disconnect Switch?
  • rupplemintz2004
  • rupplemintz2004's Avatar Topic Author
07 Mar 2006 16:26
#29137
Hey guys, newbie here. I am putting the wiring together for a KZ750 with the climbers wiring diagram and am working with reaplacemtnt parts from a running donor bike. I have the lights and blinkers working Ok so far but that is about it. Power is going into the starter solenoid but nothing cranks or reads when I thumb the starter. I cannot find the starter disconnect switch to check it. Where is the thing? Any suggestions would be much appreciated. Thanks
  • roy-b-boy-b
  • roy-b-boy-b's Avatar
Re: Starter Disconnect Switch?
07 Mar 2006 16:34
#29143
Welcome aboard! Is there fire going to the selenoid when you press the starter button? Are you holding the clutch in when you hit the starter? Just some ideas. Roy
  • rstnick
  • rstnick's Avatar
  • Premium Member
  • Premium Member
07 Mar 2006 16:35
#29144
Welcome.
On my 650, the switch is on the clutch lever. The starter wont work if the clutch is not pulled in. Other bikes have the switch on the side stand. Side stand must be up to start I think.
Post edited by: rstnick, at: 2006/03/07 19:35
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
  • indykaw77
  • indykaw77's Avatar
07 Mar 2006 17:13
#29154
It's kinda obvious, but check "Kill" switch on LH bar. Saw one way loose inside once. Wire just wore plumb thru and was hanging by a thread, literally.
Good luck.
Kawasaki Motorcycles...because cars lean th wrong way!
  • rupplemintz2004
07 Mar 2006 17:15
#29155
Wow, thanks guys, I did not even think of the clutch! Whoops. Haha, thanks I am going to take another crack tomorrow!
