Dyna 2000 timing on Z650
- ernst_himself
15 May 2009 03:07 #291331
by ernst_himself
Dyna 2000 timing on Z650 was created by ernst_himself
Hey,
I've just installed an dyna 2000 ignition with coils on my kawasaki z 650b ( upgraded to 750 ccm ) 1978. My only problem is what the total timing should be? Depending on with dyna manual I look in the answer is 30-40 degrees before TDC on the rotor at the crank. I'm afraid to destroy something if I get this wrong. If any of you are using the same dyna on a bike similar to mine please write you timing
Please help this confused Dane
- ernst_himself
25 May 2009 03:26 #293811
by ernst_himself
Replied by ernst_himself on topic Dyna 2000 timing on Z650
Anyone? come on...
- N0NB
- Blue handles better
25 May 2009 05:09 - 25 May 2009 05:10 #293812
by N0NB
Nate
1979 KZ650 (Complete!)
1979 KZ650 SR (Sold!)
1979 KL250 (For sale)
1994 Bayou 400 (four wheel peel )
Replied by N0NB on topic Dyna 2000 timing on Z650
I can tell you how to do the Dyna S, but haven't ever seen a 2000. I found that I had to read the instructions carefully at least twice as some steps were out of sequence.
With a timing light the F mark on the advancer should be lined up with the line on the gold pin for both coils at idle. Over 4000 RPM or so the advance line should line up with the gold pin. As I recall the Dyna S required setting the static timing with the rotor fully advanced which was a bit tricky, but much easier with a test light.
Nate
Last edit: 25 May 2009 05:10 by N0NB.
