Can you trust pre-set plug gap?
  • Pro_window78
  • Pro_window78's Avatar Topic Author
14 May 2009 20:43
#291281
Hi, I have a 78 kz1000, I recently put plugs in it and the thought crossed my mind that ngk plugs may not be pre-gapped. Are they? If not what is the recommended gap for my bike? Thanks all!
  • MFolks
  • MFolks's Avatar
Re: Can you trust pre-set plug gap?
14 May 2009 21:00
#291283
Try 0.28 to 0.32 for a plug gap,also a tiny bit of the silver anti-seize on the first few threads(keep away from the center electrode)will ensure the plug won't gall or seize in the sparkplug hole(s).
14 May 2009 21:11
#291286
I usually find new NGKB8ES spark plug gaps to be ideally gapped right out of the box.
Trust, but verify. :lol:
Good Luck! :)
14 May 2009 21:21
#291290
Or in metric 0.7mm - 0.8mm :)
  • loudhvx
  • loudhvx's Avatar
15 May 2009 12:05 - 15 May 2009 12:06
#291430
Good Luck! :)
Same here, and on the D8EA's too.
The only time I found one that was not gapped was when I saw the clerk drop the box on the floor. He looked at me like I was crazy when I said i wanted another one. I told him he just re-gapped the tip to ZERO". :) Sure enough, it was shorted.
(That was when they didn't have the cardboard tube on the plug in the box.)
Last edit: 15 May 2009 12:06 by loudhvx.
  • tachrev
  • tachrev's Avatar
  • Rubber Side Goes Down
15 May 2009 12:28
#291438
Good Luck! :)
Yep. I check them all as I put them in, but I have yet to need to change any.
Build Thread
  • Old Man Rock
  • Old Man Rock's Avatar
15 May 2009 12:43
#291440
Trust, but verify.
Same here, have always measured the GAP to be within spec... Notice I said always MEASURED... ;)
As the others mentioned, always check them and the Anti Sieze compound is an extremely good tip I learned from Plummen and Larry C where it should always be used when steel to aluminum is the process... ;)
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
  • bountyhunter
  • bountyhunter's Avatar
15 May 2009 13:48 - 15 May 2009 13:50
#291453
They are pre gapped and some are shipped with a plastic cylinder slipped on the end of the plug so it won't get hit if dropped. Of course, if some bozo drops it as he is putting it in.....:laugh:
+1 on using the anti sieze compound on the threads and a torque wrench to pull them down.
Last edit: 15 May 2009 13:50 by bountyhunter.
  • loudhvx
  • loudhvx's Avatar
15 May 2009 20:08
#291550
Forgot...
I'm on the silver bottle habit too ... anti-seize.
  • Dragone
  • Dragone's Avatar
16 May 2009 04:14
#291600
always double check plug gap prior to install. Although I have not used antiseize yet on the plugs. No galling issues really in that aspect. Just remember it effects torquing numbers since the plug threads are now lubed.
  • trianglelaguna
  • trianglelaguna's Avatar
16 May 2009 06:51
#291626
i just did 8 new plugs in two seperate motors....all were exact cept one....smashed closed on gap almost....and it was the one i almost put in till i eyed it wow...got to where i thought they were gonna all be good...last one was not....allways dbl check
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
