Where would you start looking??
- bowtie39
12 May 2009 20:19
Have a 81 1000K1 LTD. Been doing some routine rebuilding of brakes, cleaning and generally replacing things. Was not a basket at all, a running bike when I purchased. Probably apart 3 months and I had a trickle on it. Finished things enough for some riding and it started up fine which was last Friday. Rode it everyday since, went out this evening to go out and it didn't start. Best way to explain is on the first push of starter it turned over but not real strong and then spun out and I released starter. This spin out is something that has happened on many bikes many times. But then after I did release button all lights(dash)went out and no life at all, dead. Push starter and nothing.
Don't know how old this battery is, but thats where I will look first tomorrow.
Any other suggestions.
Roger
Roger
- The Garbone
- User is Currently waiting for his bailout check..
Re: Where would you start looking??
12 May 2009 20:51
My guess is something is going bad and you blew a fuse.. Even if the battery is bad it should give you some lights on the dash...
2007 Royal Enfield Iron
1979 KZ650 & Hack
1949 Ford 8n
1979 KZ650 & Hack
1949 Ford 8n
- MFolks
12 May 2009 21:05
I'd do this first: remove the fuses(make a map of what goes where),clean the fuse clips with a Dremel tool and small wire brush,continuity check the old glass tubed fuses with either a self powered test light or a multimeter set on OHMS.
See if the fuses metal end caps are on tight(they can fail from vibration and current surges), If they test o.k. replace them with new ones from a good auto parts store. A light spritz with some good electrical contact cleaner(NOT WD-40!) will ensure good operation.
The fuses are the AGX type(1" long) that should be 10,20 and 30 amp rated fuses. AGC fuses will not fit as they are 1 1/4" long.
- PLUMMEN
12 May 2009 21:15
have battery tested with load tester
- bowtie39
13 May 2009 20:39
Will get to the fuses. Actually, pulled one last night and noticed colored material inside and twisted the caps. One end twisted so will replace all.
Thanks all,
Roger
Thanks all,
Roger
