Using a Dyna S on a 82 1000LTD
- kano
- Not Another Bloody Limey!
Re: Using a Dyna S on a 82 1000LTD
12 May 2009 18:56Please Log in or Create an account to join the conversation.
- Buda
12 May 2009 18:58
I'm just being lazy and will go look on my bike in the morning after work.
Thanks for your replys
Tom
Tom
1982 KZ 1170 LTD
10.25 to 1 comp
K&N pods
GPZ cams
Vance&Hines pipe with comp baffle
dyna coils and wires
97 Valkyrie Standard
10.25 to 1 comp
K&N pods
GPZ cams
- kano
12 May 2009 19:03
i can give you a call and explain things better on the phone tomorrow if you would like tom.
12 May 2009 19:21 - 12 May 2009 19:24
Am questioning whether this part number 21148 on the 1982 KZ1000 LTD is a spring-weight style advancer unit?
If it is, why does Dyna make an issue about it?
[Click on image to enhance view]
[If box is blank, click it anyhow, and the diagram should appear]
Last edit: 12 May 2009 19:24 by Patton.
- kano
- Buda
12 May 2009 19:25 - 12 May 2009 19:28
I'll look in the morning and post what ever I figure out. From memory I dont Think their are any springs or weights.
Thanks Tom
Kano beat me to post so that is an mech advance
Thanks Tom
1982 KZ 1170 LTD
10.25 to 1 comp
K&N pods
GPZ cams
10.25 to 1 comp
K&N pods
GPZ cams
Last edit: 12 May 2009 19:28 by Buda.
12 May 2009 19:27
kano wrote:
Thanks, Kano!
I liked it a lot better when they called it an "advancer" instead of a "governor-breaker." :laugh:
yes it is
Thanks, Kano!
- kano
12 May 2009 19:33 - 12 May 2009 19:42
np just don't ask me how centrifugal force force works lol.
orThe apparent force, equal and opposite to the centripetal force, drawing a rotating body away from the center of rotation, caused by the inertia of the body.
the little flap bits move out the faster it spins
Last edit: 12 May 2009 19:42 by kano.
14 May 2009 04:51 - 14 May 2009 05:06
kano wrote:
Am thinking "advancer" shown in above quote is the oem style with points ignition, and retained when converting from points to Dyna-S.
And that the "advancer" pictured below, sometimes referred to as "governor-breaker," is the later oem style with electronic ignition and retained when converting from oem electronic ignition to Dyna-S. The oem electronic ignition also has a separately located "igniter" which isn't used with the Dyna-S.
[Click on image for better view]
Wondering which ignition system Dyna instructions might be referring to that doesn't have either an advancer or governor-breaker as pictured in this post, or is Dyna just saying that Dyna-S is unsuitable whenever a spring-weight advancer aka governor-breaker isn't already there?
Good Luck!
Good Luck!
Last edit: 14 May 2009 05:06 by Patton.
- Buda
14 May 2009 06:22
Thanks That one line in the instructions just made me unsure if the dyna s would work for me. The main reason I want to use it is that I have 2 sets of 3 ohm coils.
Thanks for your help
Tom
Tom
1982 KZ 1170 LTD
10.25 to 1 comp
K&N pods
GPZ cams
10.25 to 1 comp
K&N pods
GPZ cams
