- Thank you received: 6
Coil Spark Plug Wire Removal??????????
- badrhino
How do you get the Plug Wire out of the Coil. I pulled the rubber boot back and have tried to turn/pull wire out with no luck.
How do you get these wire out?
Thanks in advance.
1980 KZ1000 with a 1982 KZ1000J motor with 1100 pistons and heads, Vance & Hines, 29MM Smooth Bores, Work in Progress
Franken Z!
- MFolks
- Thank you received: 540
The coils had a brass spike inside the port that pierced the sparkplug wire transmitting the ignition energy.
Some bikes had the sparkplug wires integrated into the coils making replacement difficult.
You may have to buy a set of Dyna coils if you can't get your plug wires replaced. I think Z1 enterprises can get what you need.
- badrhino
Franken Z!
- badrhino
Franken Z!
- Thank you received: 2098
- bountyhunter
- Thank you received: 337
- badrhino
Franken Z!
- timebomb33
- Thank you received: 10
I THINK MY POWERBAND BROKE
- badrhino
There must be alot of bikes with dyna coils on here because I see alot of bikes with aftermarket wires.
Franken Z!
- PLUMMEN
- Thank you received: 104
- bountyhunter
The wires are molded into the coil for three good reasons:So are you saying that you need to buy a set of dyna coils to change spark plug wires? That sounds retarted.... why did they make the coils like that?
1) It provides mechanical (strain) relief for the wires to keep them attached.
2) It prevents vibration from shearing them off at the connections.
3) It makes the connection waterproof.
There are kits to attach wires on with splices at the edge of the potting on the coil. You can replace the wires that way.
- badrhino
Thanks
Franken Z!
