Weird little box?
  • Pro_window78
  • Pro_window78's Avatar Topic Author
Weird little box?
12 May 2009 12:31
#290543
Hey everybody, I have a little rubber/tar/black stuff covered box up by my coils. Is this an ignitor box? it plugs into the harness with a plastic 4 prong plug. The bike btw is a 78 kz1000 a2. Anybody know what the thing is? Ill try to get some pics on in a bit.
  • MFolks
  • MFolks's Avatar
Re: Weird little box?
12 May 2009 13:22
#290554
The IC Igniter boxes usually have cooling fins on them and will have "IC Igniter" with either raised or stamped lettering. They have two wire cables with a four pin connector on each. One coming from the ignition pickup coils and the other going to the ignition coils.
I can't imagine having the igniter up by the coils as this is a very hot area for electronics(unless the previous owner moved it).
My old 77 KZ1000 did not have electronic ignition but I later installed a Gearex system and sold it with the bike when I bought my 82 GPZ1100 B2 in 1982.
  • CSmith
  • CSmith's Avatar
12 May 2009 14:01
#290562
I would have to say this is your brake light bulb failure circuit detection relay. It detects when your brake light bulb has burnt out and then makes the brake light indicator in your gauge flash.
75 Z1, 1075cc, Dyna S Ignition, Mikuni RS 34mm, Inverted Forks & Mono Rear Shock.
76 KZ900 LTD Stock
80 KZ750 Dyna Ignition, Kerker pipe
  • Pro_window78
12 May 2009 14:03
#290564
cool thanks! puttin new coils on and I was hoping I wouldn't have to get into the wiring much.
