Dyna S install help
- Bullysee
11 May 2009 13:17 - 11 May 2009 19:02 #290236
by Bullysee
1983 Kawasaki KZ1100 D2
Stock
Dyna S install help was created by Bullysee
Hi, I installed a Dyna S on my bike. When I try to do Static Timing I have the test light light up for a good inch of movement.
I can turn the whole plate to the right or the left and the 1-4 timing light does not turn off. The 2-3 test does not come on until I rotate the engine but I get the same thing with that timing. It seems like it is not fine tuned if I can move the plate that far both ways and still have the test light light up.
The bike runs strong and seems to have more power. I now hear a little back fire rumble when I let off the throttle.
Some thing not right?
Thanks for the help
Thanks for the help
Stock
Last edit: 11 May 2009 19:02 by Bullysee.
- Old Man Rock
- Thank you received: 225
12 May 2009 01:05 #290469
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Replied by Old Man Rock on topic Dyna S install help
On my KZ900... I had to elongate the ignition plates slotted the screw holes...
Now I had a choice of relocating each pickup but as I observed this closure... It wouldn't have made a difference for I required more than that to reach the F marking....
So out with the drill and stretch those half moon shaped slots for additional adjustments....
OMR
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- Bullysee
12 May 2009 07:01 - 12 May 2009 09:20 #290493
by Bullysee
Stock
Replied by Bullysee on topic Dyna S install help
Thanks, I can line up 1-4 on the f mark but when try 2-3 it seems to be 180' off. Not sure what I'm doing wrong.
Do I have to turn that little place magnet piece by hand and turn the nut with a wrench at the same time?
Stock
Last edit: 12 May 2009 09:20 by Bullysee.
- loudhvx
- Thank you received: 1616
12 May 2009 09:38 #290519
by loudhvx
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Replied by loudhvx on topic Dyna S install help
Bullysee wrote:
There may not be an "f" mark for 2-3. But if there is, it will be 180 degrees away from the "f" mark for 1-4.
I usually take apart the advancer and carefully scribe a line 180 degrees from the 1-4 f mark to create a 2-3 f mark.
1981 KZ550 D1 gpz.
Other links.
- Bullysee
12 May 2009 10:14 - 12 May 2009 11:18 #290523
by Bullysee
Stock
No f mark for 2-3 only a T mark. So I will have to measure the distance..
Update:
I measured the distance from T mark to the f 1-4 mark and marked 2-3 with the same distance. Bike starts up nice and strong but I have little back fires at idle 1000rpm and throttle release. Just little ones very slight
Do I use f mark or the advanced marks?
Thanks
Update:
Thanks
Stock
Last edit: 12 May 2009 11:18 by Bullysee.
- loudhvx
12 May 2009 17:02 #290632
by loudhvx
1981 KZ550 D1 gpz.
Other links.
For static timing, you will have to use the f marks. If you have a strobe, you can use the advance marks to verify the timing.
Little backfires can be from faulty connections. Did you use the little blue wire connectors that come with the Dyna S? They have been known to cause faulty connections.
(The backfires can from many other things too.)
1981 KZ550 D1 gpz.
Other links.
- Bullysee
13 May 2009 05:11 #290753
by Bullysee
Stock
Thanks loudhvx, I did not use the little blue wire connector. I soldered the wires together.
Thanks guys for the help.
Stock
