Need Assistance 1980 KZ550 A1
- keithk
09 May 2009 04:48 #289325
by keithk
Need Assistance 1980 KZ550 A1 was created by keithk
I'm in the process of a frame off total restoration of an 80 KZ550 A1. I have the wiring harness back in along with the fuse holder bracket, turn signal relay, etc. My problem is that for the life of me I cannot figure out where the starter relay and a couple of connectors go. If anyone has this bike would you mind shooting a couple of photos under each side cover to help me. I have the Clymer, and the OEM illustrated parts manual but neither help. Any assistance would be GREATLY appreciated.
- GPz550D1
- Thank you received: 22
09 May 2009 05:05 #289329
by GPz550D1
1981 KZ550-D1
Replied by GPz550D1 on topic Need Assistance 1980 KZ550 A1
Sorry, do not have a camera, but I have a '81 KZ550. If yours is the same as mine, the relay goes underneath the fuse box. The rubber mounting is made so that it just slides into place. The connectons are relatively easy, you should have one male and female connector for the small wires. I don't think it matters which terminals you use for the two big wires, since both wires carry positive current. Hopefully, yours is just like mine and I apologize if it is different. Maybe someone will be able to take a picture for you.
Robert
Robert
1981 KZ550-D1
- SPARKY47
- 1980 KZ500 B2
- Thank you received: 5
09 May 2009 10:03 #289387
by SPARKY47
1980 KZ500 B2
Replied by SPARKY47 on topic Need Assistance 1980 KZ550 A1
Keithk, sorry, got a digi camara but retarded so cant use it.:woohoo:
Heres a webcam photo taken out of the kawa workshop manual pg 225 for the kz400,kz500/550.
1980 KZ500 B2
- keithk
10 May 2009 05:04 #289744
by keithk
Replied by keithk on topic Need Assistance 1980 KZ550 A1
All fixed. Was using the wrong relay. Found the original tucked away in a spare parts box. Thanks for your help!
