Other Options For Stator......
  • gershom
  • gershom's Avatar Topic Author
08 May 2009 07:50
#289030
I'd like to remove my stator and remove the stator cover permanently. I've seen a charging system before that fits on the right side of the motor under a modified points cover. Anyone else familiar with this?
The project is a 78 KZ1000A2A done up in era correct Superbike like form.
1978 KZ1000A2A, 1971 CB500K, 1972 CB350F, 1974 Guzzi 850T, 1974 Guzzi 850T, 1975 Guzzi 850T Hot Rod, 1966 BSA A65 Lightning, 1978 SR500
  • trianglelaguna
  • trianglelaguna's Avatar
Re: Other Options For Stator......
08 May 2009 08:07
#289032
i think muzzy superbikes ran a kx80 dirt bike magneto type thingy there.....in keven camerons book "top dead center" there is a whole chapter written about rob muzzy building the kawasaki for a race bike where kevin is literaly walking throught the race shop back in the day and pointing at parts and discussing the tech tricks of each part and such...its really informative and i think the book is a must to regain little not easy to find knowlege peices for what folks were doing on those and other era bikes...i got mine of ebay or amazon.....pictures of your retro racer would be great...also you may wanna update your signiture in your rpofile to add your year/models/ mods/ general state and location ect...so folks will know what your up to better.....peace craig
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
  • gershom
08 May 2009 08:25
#289037
Interesting......I'll have to get the book.
With no stator or starter, it'll be a big weight savings. The kicker will be sufficient for starting a 10:1 motor.
Just need a charging system that will support a low beam headlight and some LED turn signals housed in stock signal housings.
  • PLUMMEN
  • PLUMMEN's Avatar
08 May 2009 10:40
#289054
talk to lou about one of his capacitor charging setups to eliminate battery,still need some sort of stator for it though im thinking B)
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
08 May 2009 11:07
#289055
FYI lou = loudhvx :)
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
  • loudhvx
  • loudhvx's Avatar
08 May 2009 13:24
#289069
Hey y'all :)
Man, there's not much room under that right side points cover. You might squeeze in a mini magneto, but it won't handle much power. Maybe enough for an ignition, but not a strong ignition. Any lighting winding will really cramp the area under the cover and it won't have much power for sure.
With a magneto, you still need to have points or an electronic ignition to trigger the magneto. A magneto is basically a small, dedicated stator to power the ignition coil. Magnetos work like CDI, which means they have a lot of voltage... useful for 2-strokes or high comp race bikes... but not a lot of spark energy because of their short duration.
I guess the first place to look for one would be old Kaw dirtbikes.
