New (to me) kz750 (sort of)
- jjdtaylor
06 May 2009 20:52
My wife bought me a bike for my b-day and I have a few questions:
1) It's titled as a 77 kz650, but it has an '82 750 engine. What's the best way to describe it without having to explain every time someone asks what I ride?
2) The neutral light doesn't come on when the bike is in neutral, but it does flicker when going down the road. Is this an electrical gremlin, or could it have something to do with the engine swap?
3) Turn signals don't work at all, same question as above.
4) The carbs need sync'd; not knowing much about carbs, should I even attempt to do this myself? (shop wants $100)
5) Even with all this, I rode it home (45 min), and aside from being a little underpowered (I assume due to the carbs needing sync'd) it ran great. Any thoughts or opinions out there considering it cost less than $600? (ie did I get burned)
Thanks
Thanks
- l0g1c
- Hanging on for dear life.
Re: New (to me) kz750 (sort of)
06 May 2009 20:56
$600 for a runner. I'd say that alone means you got your money's worth. Got any pictures to share?
'81 KZ750 LTD
'72 CB350K
Omaha, NE
'72 CB350K
Omaha, NE
- jordan
06 May 2009 21:18
$600 sounds like a pretty good deal to me. I really dont like working with electrical stuff so i would probably just leave it, unless it really bothers you. Hand signals can replace the need for blinkers. Unless you drive a busa every day, the 750 shouldnt feel underpowered to most people, so something must be wrong. As for price, $100 might not be that bad if you dont have the tools to do it yourself, or know anybody with the tools.
KZ810 streetfighter kz/gpz/gsxr
1983 gs1100e
1979 KZ 1000 1428 dragbike project
1974 kawasaki H1 500 sold
1972 Kawasaki s2 350-parted on ebay
1973 Kawasaki s2 350-parted on ebay
1982 kz750(sold)
1978 kz650 hardtail(sold)
1975 honda xl250-sold
1971 yamaha R5-sold
1982 yamaha xs400
1983 gs1100e
1982 kz750(sold)
1971 yamaha R5-sold
1982 yamaha xs400
- The Gringo
- ¡Usted no necesita otra motocicleta!
07 May 2009 00:52
Your problem with the neutral light sounds like you may have a bad ground. Check the neg cable coming off the battery and make sure the connection on both ends are clean and tight. This may be what's causing the turn signal problem as well.
Andy
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
KZ 550 times 2 80 440LTD-Sold
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
- hugo
- '92 Zephyr 750
07 May 2009 07:31 - 07 May 2009 07:37
Just buying a decent carb synchronizer, like a Morgan carbtuner would cost more than $100.00. I do all my maintenance, therefore, to me is worth it. Once you learn about, synch'ng carbs is easy, and then you can always do it yourself.
All that said, in your case, I would also disassemble and clean the carbs before anything. As probably you don't know if it is lack of synch, or lack of cleaning,..... likely it needs both. Again, this is mostly labor intense, if you research it.
Last edit: 07 May 2009 07:37 by hugo.
