NGK Plug Cap Size?
  • athlonwirez
  • athlonwirez's Avatar Topic Author
NGK Plug Cap Size?
06 May 2009 08:33
#288468
I just ordered some VD05 (120 deg.) and LD05 (90 deg.) resistor plug caps, because a couple on the bike that my father-in-law is going to give me (1978 1000LTD) were broken. My question is will these fit standard plugs? These are suppose to be for 10 and 12 mm plugs, while the VB05 and LB05 are for 14mm plugs. On the NGK site HERE I do not see much difference. I only see some small length differences, yet no diameter differences. What do you all think?
1978 LTD Partial Restoration in Process. (Do not have orginal exhaust)
  • otakar
  • otakar's Avatar
Re: NGK Plug Cap Size?
06 May 2009 11:29
#288490
The diference is in the little rubber boot that seals around the cap and the plug.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
  • MFolks
  • MFolks's Avatar
06 May 2009 13:17
#288516
The NGK sparkplug caps grip the threads on top of the sparkplugs. Most plugs have a terminal that unscrews allowing the NGK cap to push on making electrical contact.
  • athlonwirez
07 May 2009 08:15
#288719
Thanks! I hope they work.
