DIAMOND (CRYSTAL) 7" HEAD LAMP
  • otakar
  • otakar's Avatar
Re: DIAMOND (CRYSTAL) 7" HEAD LAMP
08 May 2009 06:13
#289007
You do not require a relay. Your old system drew 5 Amps. I ran a 100W bulb which draws 8.3 Amps and had absolutely no problem. Your HID system draws only 2.9 Amps. as I said no Relay necessary.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
  • otakar
  • otakar's Avatar
08 May 2009 06:23
#289008
There is no brand on the HID system. I bought them bulk from China, and they do not label it. It is just referred to as the "Mini Ballast" The complete system for the bike for an HI/LO H-7 conversion is $85 The Hi beam is quartz.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
  • otakar
  • otakar's Avatar
08 May 2009 06:23
#289009
2
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
  • otakar
  • otakar's Avatar
08 May 2009 06:24
#289010
3
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
  • otakar
  • otakar's Avatar
08 May 2009 06:27
#289012
4
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
  • otakar
  • otakar's Avatar
08 May 2009 06:32 - 08 May 2009 06:35
#289013
Here is what you get in the complete set.
It took me about a half hour to install, and that is only because I had to take off and remount a fairing. It is strictly plug and play. No wire cutting at all. The process is 100% reversible. Just unplug the system and plug in your old bulb.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 08 May 2009 06:35 by otakar.
