DIAMOND (CRYSTAL) 7" HEAD LAMP
- Treeman
- 1984 KZ 700 A1
05 May 2009 06:28 #288075
by Treeman
1984 KZ700 A1
2005 Harley Softail Springer Classic
Palmyra, NY
DIAMOND (CRYSTAL) 7" HEAD LAMP was created by Treeman
Any one purchased and used one of these? It's on ebay when I do a search for kz700.
Thanks
Thanks
1984 KZ700 A1
Palmyra, NY
- CSmith
05 May 2009 07:06 #288085
by CSmith
75 Z1, 1075cc, Dyna S Ignition, Mikuni RS 34mm, Inverted Forks & Mono Rear Shock.
76 KZ900 LTD Stock
80 KZ750 Dyna Ignition, Kerker pipe
Replied by CSmith on topic DIAMOND (CRYSTAL) 7
I bought one about 2 months ago. It is "Hella" brand. I bought this along with a HID kit it worked out very nice for me.
76 KZ900 LTD Stock
- Audinos
- Thank you received: 1
07 May 2009 11:47 #288762
by Audinos
Replied by Audinos on topic DIAMOND (CRYSTAL) 7" HEAD LAMP
In general, Hella makes very good quality lights. The 500 driving series I use on my car are almost as good as PIAA or Bosch pencil beams costing hundreds more.
Does this light require a new headlight bucket or will it fit the stock one? Does it draw the same current as the stock light or did you have to do some new wiring?
- otakar
07 May 2009 12:01 #288765
by otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
Replied by otakar on topic DIAMOND (CRYSTAL) 7" HEAD LAMP
Hay CSmith
When you say that you got it with the HID kit. Are you saying that you got the Blue Quartz bulb with it or that you bought the Xenon HID system with the ballast and the wiring harness. This is what I put on my bike. Obvious difference is the shape.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- otakar
07 May 2009 12:02 #288766
by otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- otakar
07 May 2009 12:03 #288767
by otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- otakar
07 May 2009 12:05 #288768
by otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- otakar
07 May 2009 12:07 - 07 May 2009 12:12 #288769
by otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Power ON :woohoo:
I finally rode it at night last night. It throws out a tremendous amount of light. This is the 6000K bulb so it is light blue. I also have an 8000k bulb which is more blue yet. It only consumes 35W of power but puts out about 3.5 times as much light as my old Quartz Halogen Bulb.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 07 May 2009 12:12 by otakar.
- riverroad
- 1980 1000LTD B4
- Thank you received: 7
07 May 2009 12:34 #288776
by riverroad
Replied by riverroad on topic DIAMOND (CRYSTAL) 7" HEAD LAMP
Sure wish somebody would make a ballast small enough to fit inside my headlight housing.
- otakar
07 May 2009 13:33 #288786
by otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- CSmith
07 May 2009 20:45 #288948
by CSmith
76 KZ900 LTD Stock
Replied by CSmith on topic DIAMOND (CRYSTAL) 7" HEAD LAMP
The one I bought was a 7" round.
I also bought a Xenon HID kit...looks a lot like the one in the photos above. I remote mounted the ballast from the headlight bucket. Everything else fit inside.
The HID kit I bought came with a relay to power the kit. No need to worry about the power draw thru the old switches and wires.
76 KZ900 LTD Stock
- riverroad
- 1980 1000LTD B4
08 May 2009 06:12 #289006
by riverroad
