Bad ground on KZ550
  • nosbearatu
  • nosbearatu's Avatar Topic Author
Bad ground on KZ550
29 Apr 2009 08:53
#286204
I have a 1981 KZ550, I have been having weird electrical problems recently. Every so often when I go to start the bike I will get a solenoid click from the starter rather than it turning over. This seems to be remedied by grounding the negative battery terminal against the frame.
My question is where is the ground located on this bike, I've looked but, I'm having trouble tracing the wires.
  • JCollict
  • JCollict's Avatar
Re: Bad ground on KZ550
29 Apr 2009 10:09
#286218
At the end of the top frame tube under the tank.
  • MFolks
  • MFolks's Avatar
29 Apr 2009 10:58
#286228
If it was me,I'd get some 6 gauge welding cable, some correct sized terminal lugs and electrically tie the negative battery post to a engine mounting bolt.
This makes for a sturdy,high current ground.
  • nosbearatu
29 Apr 2009 11:01
#286230
Thanks guys, I will give it a try when I get home.
  • The Gringo
  • The Gringo's Avatar
  • ¡Usted no necesita otra motocicleta!
29 Apr 2009 12:02
#286243
On a KZ550 the main ground is located just behind the rear brake light switch on the RH side of the bike. It screws into the engine cases just below where the upper rear motor mount is located. Just follow the negative cable coming off your battery and you'll find it.
Andy
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
KZ 550 times 2 80 440LTD-Sold
  • hoghaterkaw
  • hoghaterkaw's Avatar
29 Apr 2009 13:34 - 29 Apr 2009 13:35
#286253
Gringo has it right.
Last edit: 29 Apr 2009 13:35 by hoghaterkaw.
  • JCollict
  • JCollict's Avatar
08 May 2009 12:49
#289065
Hmm, mine's a UK model so may be different but my ground from the battery is at the rear of the spine just behind the tank locating rubber. God only knoews if that's where it should be if that is the case.
