stock ignition or upgrade?
- brianrae33
28 Apr 2009 06:11
is it worth replacing the factory ignition on the 82 ltd1000...or would a simple coil upgrade be sufficient??i've heard the kaw ignitions are pretty well built..
1982 kz1000ltd
- loudhvx
Re: stock ignition or upgrade?
28 Apr 2009 09:01
Depends on what you want to do. For a stock engine, the stock electronic ignition is more than adequate, and is very efficient on power.
Are you having ignition problems? If the coils are original they may be on their way out, especially if they have tiny cracks on them.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
- Buda
29 Apr 2009 06:10
What ohm coils should be used for this bike.
Thanks
Tom
Thanks
Tom
1982 KZ 1170 LTD
10.25 to 1 comp
K&N pods
GPZ cams
Vance&Hines pipe with comp baffle
dyna coils and wires
97 Valkyrie Standard
10.25 to 1 comp
K&N pods
GPZ cams
- loudhvx
29 Apr 2009 08:11
I would suspect the coils are 2.5 ohms as that is what the majority of KZ electronic ignition coils are. The only exception may be some of the 79 and maybe 80 models with electronic ignition.
1981 KZ550 D1 gpz.
Other links.
Other links.
- Buda
29 Apr 2009 08:29
I think the ones I have are 3ohm will that cause me any trouble?
Thanks
Tom
Thanks
Tom
1982 KZ 1170 LTD
10.25 to 1 comp
K&N pods
GPZ cams
10.25 to 1 comp
K&N pods
GPZ cams
- MFolks
29 Apr 2009 08:43
My understanding is don't go lower in coil resistance from stock but go up. 2.5 to 3.0 ohm should work o.k.
- loudhvx
29 Apr 2009 10:57
Yes, like MFolks says, 3.0 ohms should be fine with the stock electronic ignition.
If you go too low, you exceed the safe current levels for the electronics and they can burn out.
If you go too high, like 4 or 5 ohms, you will start to lose spark energy because the dwell is designed for lower resistance coils.
1981 KZ550 D1 gpz.
Other links.
Other links.
- Buda
29 Apr 2009 16:25
Thanks Guys I read somewhere that with the 3 ohm coils I would get weak spark. Sounds like my coils are ok.
Tom
Tom
1982 KZ 1170 LTD
10.25 to 1 comp
K&N pods
GPZ cams
10.25 to 1 comp
K&N pods
GPZ cams
- brianrae33
30 Apr 2009 06:17
pretty sure z1 has 2.2 ohm coils very reasonably priced..i'll check there..
1982 kz1000ltd
