ignition on a zn700 help
- sharkynrk
27 Apr 2009 11:34 #285706
by sharkynrk
ignition on a zn700 help was created by sharkynrk
finally getting my project zn700 close to running ( i finished building a new wiring harness for it) and found out the ingition module is flat missing. on ebay people want like $200 for a used box off a zn (#21119-1108 or 9) and that like 2/3 of what I have in the project. I can find easier and cheaper boxes from a kz750 (#21119-1119 or something similar). I know the firing order of all of these model inline fours is the same and the difference is in the curves or physically with plugs and size. does anyone know more on this and can help me out - I really can't afford to spend $150-200 on a freaking used part for a $500 bike
- timebomb33
- Thank you received: 10
27 Apr 2009 11:41 #285710
by timebomb33
I THINK MY POWERBAND BROKE
Replied by timebomb33 on topic ignition on a zn700 help
go to a dyna s system and you don't have to worry about the ignition box it is all self contained the only thing it won't have is a rev limiter
- sharkynrk
27 Apr 2009 11:45 #285713
by sharkynrk
Replied by sharkynrk on topic ignition on a zn700 help
while I am sure an upgrade ignition would be nice - I am sure the cost is much greater than what i can afford at the moment
- timebomb33
27 Apr 2009 14:03 #285742
by timebomb33
the cost of a dyna s plate will be cheaper than buying a replacement ignition box of that i'm sure.
- sharkynrk
27 Apr 2009 14:25 #285752
by sharkynrk
where can i get one, I think i saw a dyna 2000 for $389 on z1 - thats pretty expensive for this project
- timebomb33
27 Apr 2009 14:39 #285759
by timebomb33
that is a complete controller all you need is the plate all that is needed is the plate and after a while if you so decide you can also add a rev limiter if needed the dyna s plate you should be able to get anywhere try z1 enterprises.
- sharkynrk
27 Apr 2009 14:51 #285766
by sharkynrk
looked on z1 - its for $120 which is quite a bit more reasonable, however my bike is an 84 and already has electronic ignition stock so i don't think it will work as its to replace points
- loudhvx
- Thank you received: 1616
27 Apr 2009 22:28 - 27 Apr 2009 22:38 #285906
by loudhvx
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Replied by loudhvx on topic ignition on a zn700 help
sharkynrk wrote:
It's a matter of the advance mechanism. If your advance is done electronically, the Dyna S won't work. If your advance is mechanical, a Dyna S will work, but you will need 3-ohm coils too ($100 to $200). Yours are probably 2.4 or 2.5 ohm.
EDIT: I just checked. Yours is electronic-advance. In order to use a Dyna S, you'd have to buy a mechanical advancer from a KZ 500, 550, 650, or 750. Then verify the advance curve. (And you'd still need new coils.)
Another option is to get the advancer and pickup plate from an early (81 to 83) KZ550 or 750. That'd probably run $50 on ebay. Then make an igniter for about $35.
www.geocities.com/loudgpz/GPZgmHEImod.html
You could still use your stock coils.
1981 KZ550 D1 gpz.
Other links.
Last edit: 27 Apr 2009 22:38 by loudhvx.
- sharkynrk
30 Apr 2009 06:34 #286490
by sharkynrk
got a ic ignitor from a guy for $80 - thanks for the replies
