just ordered a Dyna from Z1
  • jzanutto
  • jzanutto's Avatar Topic Author
27 Apr 2009 11:28
#285701
I just ordered the Dyna points eliminator for my 78 650. Didnt want to go big money on a full dyna with coils and all, just the points eliminator electronic pickups.
so what can expect to see when its all installed and first fired up??? noticeably smoother?
1978 KZ650B 2004 BMW R1150RT
  • timebomb33
  • timebomb33's Avatar
Re: just ordered a Dyna from Z1
27 Apr 2009 11:30
#285703
you will like the dyna s it works great set and forget it and the bike should be easier to start and also run smoother
I THINK MY POWERBAND BROKE
  • Bluemeanie
  • Bluemeanie's Avatar
28 Apr 2009 06:08
#285946
After installing (DO NOT use the blue connecter supplied, solder that connection!) and timing my Dyna S, I was amazed at how fast my 650 fired up. I used to say "check this out honey!" as the bike fired up within two revolutions. She just rolled her eyes and walked away muttering "that's nice dear". I had also installed new carb boots, rebuilt carbs, plugs, Andrews coils, WG mod, etc, so your results may vary. :)
  • HerrDeacon
  • HerrDeacon's Avatar
28 Apr 2009 07:55
#285962
I installed a Dyna S, Dyna 3ohm coils, new plug wires this winter and just started it this past weekend for the first time. I found it ran smoother and throttle response was much better.
Installation is a breeze, even for a electrical idiot like me :) Timing is easy as well.
Now keep in mind that I also adjusted the valves and cleaned the carbon off the pistons and head so I'm sure this helped as well. I already had the coil mod done last year.
So far I'm very pleased though.
  • RonKZ650
  • RonKZ650's Avatar
28 Apr 2009 09:43
#285987
I've got the Dyna on 3 650s. To be honest i could tell no difference in starting or running, but the great thing is you don't have to constantly fiddle with it like points so well worth it just for that. Also did the coils, saw no improvement there either so just went back to stock on the coils.
