Blown Headlight Question?
- Russ Jackson
27 Apr 2009 05:59
Two weeks ago The headlight on my bike stopped working. First the low beam then two weeks later the high beam went out. I figured it was just an old lamp. So I changed it with the same Sylvania Headlight. Both High and Low burned out in two weeks. Any suggestions? Everything else is fine including turn signals, brake, and tail light...Russ
1976 KZ 900 B1 29 smoothbores, Kerker, Lester Mags
2008 Kawasaki Concours 14 abs
Re: Blown Headlight Question?
27 Apr 2009 06:47
Russ Jackson wrote:
Possible regulator failure. Replaced mine years ago with reg/rec combo unit from Z1E and still working fine.
If not already done, could test charging system by measuring voltage across battery terminals at 4000 rpm and look for 14-15 volts. Over 15 volts indicates failed regulator, whereby excessive charging voltage may blow headlight.
Good Luck.
Good Luck.
- Russ Jackson
27 Apr 2009 08:00
About what I figured. The regulator is old and I will replace it either way. I am thinking about a Halogen replacement. Also for those who have replaced a headlight lately. If you buy one at an auto store it will cost $23.00 buy one from Z1
www.z1enterprises.com/detail.aspx?ID=2090
for $5.97...Russ
- MFolks
27 Apr 2009 10:38
I'd check the other bulbs too. Instrument,turn signals,and brake lights.
- Russ Jackson
27 Apr 2009 10:57
MFolks wrote:
All that is fine...Russ
- gane
27 Apr 2009 16:44
Just a thought, voltage spikes/reg. problems usually take out other bulbs as well. Vibration is also a common killer of H/L bulbs. try checking H/L shell for contact to bits, and deterioration of h/l rubbers. luck g
[img][/img] 1977 KZ1000A1
- Sandy
- Fly High,Tony
27 Apr 2009 21:10
This was brought up not too long ago...
kzrider.com/index.php?option=com_kunena&...ew&catid=4&id=274042
1977 KZ1000 A-1
