Starter Clutch Problem
- saltydog
24 Apr 2009 06:49 - 24 Apr 2009 07:04
Yesterday, while away from home, I went to start my KZ1000. The starter motor ran but would not engage. I push started the bike and got home. After shutting it down, I attempted a restart and it worked perfectly.
I guess my question is, is this a one time fluke or do I need to tear it down and find the problem?
After looking at the parts diagram, it does not appear to be a complicated mechanism. I would think that at least one of the three springs and pins would have attempted to engage.
I sure wish it had a kick starter.
Any help, insight, or suggestions would be appreciated.
Thanks,
Robert
Thanks,
Robert
1981 KZ1000 CSR, 1982 KZ440 ltd, 1972 Honda ct90, 1978 KZ 650
Last edit: 24 Apr 2009 07:04 by saltydog. Reason: Change subject line
- jzanutto
Re: Starter Clutch Problem
24 Apr 2009 12:40 - 24 Apr 2009 12:43
thats what my 650 started doing. Your starter clutch is starting to come apart, you will need to replace it. It starts looking like this, and it begins shedding metal shavings into your engine oil...
1978 KZ650B 2004 BMW R1150RT
Last edit: 24 Apr 2009 12:43 by jzanutto.
- saltydog
24 Apr 2009 14:59
I see that the metal cover has been beat up. Is that all that was wrong with your starter clutch?
Thanks,
Robert
Thanks,
Robert
- keith1
24 Apr 2009 16:01
saltydog wrote:
when i bought my bike, did the same thing......i rebuilt mine....getting to it is the toughest part...the thing is , you need all 3 springs and pins to engage to get it operational....redline cycle has a great section on what to look for as far as wear .....good time to replace that grommet for wiring while you are in there....good luck.....keith
Thanks,
Robert
- jzanutto
24 Apr 2009 17:22
no if you look closely inside you will see one of the spring loaded plungers has come apart , the clutch would engage sometimes, others it wouldnt. But it really chews itself up and you will have metal in your oil pan
- saltydog
25 Apr 2009 20:52
I found the problem!
After the bike failed to start again, I removed the alternator cover. It turned out that the bolt that holds the rotor on had gotten loose. The starter clutch looks undamaged. I'll put it all back together tommorrow and see if it works properly.
Thanks for all the comments and advice.
Robert
Robert
- jzanutto
25 Apr 2009 21:21
you took out the starter clutch and checked it?
- saltydog
26 Apr 2009 04:45
Yes. The rotor was spinning free on the shaft.
- franknsr
26 Apr 2009 06:44
The alternator rotor is under the alternator cover, he's referring to the starter clutch which is inside the crankcase.
If that was loose you have another problem. There should be a key on the alt rotor to keep it from spinning.
Formerly CSRchopper
1991 KZ1000P
Gone but not forgotten
1986 ZG1000
1982 650 CSR -shoulda kept this one-
Lisle Illinois, USA
1991 KZ1000P
1986 ZG1000
Lisle Illinois, USA
- OnkelB
26 Apr 2009 07:00
Guys, Saltydog is talking about a KZ 1000. The big bikes (900/1000/1100) have the starter clutch sitting on the left end of the crankshaft behind the alternator rotor.
77 KZ 650 B1, 82 GPz 1100 B2.
