Dyna III ignition, setting timing?
- Pro_window78
22 Apr 2009 22:10
How does one go about setting timing on a dyna III ignition? My 78 kz1000 is equipped with one and I have the mark set in the middle of the little round "window" in the plate. Is this correct? I had to replace the ignition housing and I just want to make sure. thanks
- loudhvx
Re: Dyna III ignition, setting timing?
22 Apr 2009 23:40
If you can find the instructions for the Dyna S (online), it should be almost the same.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
- Pro_window78
- Jeff.Saunders
23 Apr 2009 11:36
www.dynaonline.com/skins/downloads/instruct/D32-1_32-2.pdf
Dynatek still has the Dyna III instructions online
- Pro_window78
