Dyna coil question
  • dshelly
  • dshelly's Avatar Topic Author
Dyna coil question
22 Apr 2009 10:00 - 22 Apr 2009 10:02
#284052
I,ve got a question about dyna coils. The 3 ohm green ones. I have two cylinders with sooty plugs. #1 and #2. The other two are nice and light brown. Running a Dyna s ign. and dyna wires. both new. timing is dead on and carbs have just been rebuilt and jetted identically. Also have done wired george coil relay mod.
So my question is.,,, can the coils produce a weak spark on one wire and a good spark on the other?
I forgot to mention , the bike is a '77 kz1000
Occupation:Machinist 25+ exp.
'77 Kz1000B1
'78 Kz1000A2
'76 Kz900LTD
Last edit: 22 Apr 2009 10:02 by dshelly. Reason: forgot info
  • MFolks
  • MFolks's Avatar
Re: Dyna coil question
22 Apr 2009 10:38
#284059
My understanding is the left coil fires plugs 1 & 4 and the right coil 2 & 3. How is compression on the sooty cylinders? Valve clearances been checked? Engine smoking on start up?
  • dshelly
22 Apr 2009 10:48
#284063
compression is 135-140 all the way across. just did the valves this spring.
'77 Kz1000B1
'78 Kz1000A2
'76 Kz900LTD
  • MFolks
  • MFolks's Avatar
22 Apr 2009 11:10
#284070
Switch the plug and coil wires to see if the problem moves to the other good plugs to determine if the coil has gone bad(make a map of where the wires go before and after to reduce confusion).
22 Apr 2009 13:28
#284097
If not already done, would also assure fuel levels in carb float bowls #1/2 are not too high, by using clear tube test method.
Good Luck! :)
  • Old Man Rock
  • Old Man Rock's Avatar
22 Apr 2009 18:51
#284199
Oh-Oh!!!!! :ohmy: Here we go..............
"carbs have just been rebuilt and jetted identically"
What about the air/mix/pilot screw adjustments and synch adjustments, have these been performed?
As Patton mentioned, float heights correct?
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
  • dshelly
23 Apr 2009 05:00
#284324
Well,
Patton hit the nail on the head. The float levels on 1 and 2 were a little on the high side. Probabbly around 1mm high ,but just enough to make them run too rich.
I guess the coil idea was just another brain fart on my part. :unsure:
'77 Kz1000B1
'78 Kz1000A2
'76 Kz900LTD
