fried plugs
- dodak1967
fried plugs
22 Apr 2009 00:51
I have an 80 KZ1000LTD. Twice a season I have to change the spark plugs. As the go bad the bike will idle rough and lower than normal when cold. After a minute or two of warming up the rpms rise and the idle smoothes out. When I pull the plugs the insulator is white and the electrode is pitted and produces a weak spark. I tried richening the fuel/air mixture, raising the jet needles with the same results. Any suggestions would be appreciated.
Tom in West Allis, Wisconsin
Re: fried plugs
22 Apr 2009 01:50
If believed running too lean, could check service fuel level in float bowl using clear tube test method. A too low fuel level can cause too lean fuel mixture.
Good Luck!
Good Luck!
- timebomb33
Re: fried plugs
22 Apr 2009 07:53
sounds like you have some cracks in your intake manifolds or are leaking somewhere are all plugs the same if they are it also could be a fuel related problem what type of fuel are you using.
I THINK MY POWERBAND BROKE
