78 KZ1000A2A No Electrical Power
- RonKZ650
Re: 78 KZ1000A2A No Electrical Power
22 Apr 2009 06:41
This problem is usually fuse clips have gone bad and melted the 20A fuse or the ignition switch has bad contacts and melted the wires off the switch. I wouldn't use a $15 switch unless for sure that is the problem. Switch is no longer available through Kawasaki so any aftermarket switch will be chinese and take some fabrication to make work. Kawasaki was over $100 for the switch when it was last sold.
- violentvintagecycles
22 Apr 2009 09:41
Not sure if you have them on your bike, but check under the headlight for 2 grounds, attached to the signals.
- gershom
22 Apr 2009 11:00
RonKZ650 wrote:
The Emgo from Parts Unlimited has the correct connector and everything. Before I try it, I will make sure it pins out correctly.
1978 KZ1000A2A, 1971 CB500K, 1972 CB350F, 1974 Guzzi 850T, 1974 Guzzi 850T, 1975 Guzzi 850T Hot Rod, 1966 BSA A65 Lightning, 1978 SR500
- gershom
22 Apr 2009 11:01
violentvintagecycles wrote:
Thought those ground washers were strictly for the turn signals in the front. Anyways, those looked good. I will know more tonight........
- gershom
24 Apr 2009 13:18
So, here's a lesson to all. Don't check a battery by doing just a voltage check with a multi meter.
Checked it using my test light and it took a few seconds before the light would glow. Hooked a booster pack to the battery cables and everything works fine.
I feel pretty dumb right now!!
- timebomb33
24 Apr 2009 13:22
you wont make that mistake again so it was a lesson learned then always make sure that you have proper battery voltage before you lose your mind.
I THINK MY POWERBAND BROKE
