78 KZ1000A2A No Electrical Power
21 Apr 2009 20:23 #283917 by gershom
78 KZ1000A2A No Electrical Power was created by gershom
Hello. Kind of frustrated.
Rode my 1978 KZ1000A2A that is just about completely stock with the exception of a 4 into 1 V&H and pod filters. Rode around twenty miles, stopped at a friends house. When I went to leave, no dash lights or anything came on. It acted like a dead battery. I checked the battery and it was fine and connections looked good. Checked the cables and ground and all checked out good. I took the ignitions switch out and disassembled it and all the contacts looked good. The fuses all tested out fine.
Could it be the ignition switch is bad??
Any help is much appreciated.
1978 KZ1000A2A, 1971 CB500K, 1972 CB350F, 1974 Guzzi 850T, 1974 Guzzi 850T, 1975 Guzzi 850T Hot Rod, 1966 BSA A65 Lightning, 1978 SR500
21 Apr 2009 20:24 #283919 by timebomb33
Replied by timebomb33 on topic 78 KZ1000A2A No Electrical Power
are you getting any power to the main fuse and have you checked it with a voltmeter or at least a testlight. doube check your grounds going to the engine cases.
I THINK MY POWERBAND BROKE
21 Apr 2009 20:26 #283920 by gershom
Replied by gershom on topic 78 KZ1000A2A No Electrical Power
I will check to see if there is power at the main fuse tomorrow. The bike is over at my buddies house.
If there isn't power to the main fuse, then what?
If there is power then what?
21 Apr 2009 20:33 #283923 by timebomb33
make sure your getting 12 volts at least and check bothsides of the fuses they will sometimes fail and not be noticable. check the voltages at the coils as well it also should be 12 volts in fact every thing you check should have 12 volts at least. try the run switch at the bars and see if you have any power there as well on both sides of the switch.lots of things to check so narrow it down.
21 Apr 2009 20:37 #283926 by gershom
I am fairly certain there was 12V at the main fuse. I used a volt meter, but I will check again tomorrow. I also cycled all the switches on the handlebars with no reaction.
It just seems weird that in less than fifteen minutes the bike went from operating perfectly, to being completely dead.
21 Apr 2009 20:42 #283928 by MFolks
Replied by MFolks on topic 78 KZ1000A2A No Electrical Power
I'd check all the "bullet" style connectors and the other connectors. Something may have vibrated loose or is not making a good electrical contact.
21 Apr 2009 20:43 #283929 by gershom
I did check all of those in the headlight housing, under the tank and under both side covers.
21 Apr 2009 20:46 #283931 by MFolks
Yet the battery has 12 volts but nothing when you turn the key and push the start button? Can you bypass the kill or stop switch?
21 Apr 2009 20:46 #283932 by timebomb33
i find that when im looking for the problem it is quicker to use a testlight once you know that you have proper voltage in the system.
21 Apr 2009 20:49 #283933 by gershom
Agreed and I have a really nice Snap On one here at home.
Do you think I should buy a new ignition switch assembly tomorrow...they only cost $15?
22 Apr 2009 01:45 #283988 by donthekawguy
Replied by donthekawguy on topic 78 KZ1000A2A No Electrical Power
Pull the switch out and check it over good. It sounds like a wire came loose because you have no lights when you turn the key on. That is if the main fuse is good.
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
22 Apr 2009 06:14 - 22 Apr 2009 06:15 #284007 by arai59
Replied by arai59 on topic 78 KZ1000A2A No Electrical Power
Happened to me once. Checked fuses by eye looked good but one end of main fuse (unseen) was rusted out. Replaced all fuses, problem solved.
Last edit: 22 Apr 2009 06:15 by arai59.
