reassembly of the advancer unit
- jzanutto
21 Apr 2009 18:56
hmmmm, cleaned up and lubed my advancer and now going back together it looks like when you put the collar back on the advancer body you can have the contact point lobe point toward the 1-4 mark or the 2-3 mark.
which way should it go???? my book doesnt show.
1978 KZ650B 2004 BMW R1150RT
- gane
Re: reassembly of the advancer unit
21 Apr 2009 19:11
J, was there last week, fat portion of cam was @ 30 degrees before 1-4 marking. no big deal. it's right or wrong. swap only takes a couple minutes and no harm done , or can swap wires. G
[img][/img] 1977 KZ1000A1
- jzanutto
21 Apr 2009 19:42
thats what I was thinking too, I could always just reverse the wires if necessary. But being I'm a semi-perfectionist I think I would have to take it all back apart and do it over
- gane
21 Apr 2009 19:54
j. my reference was 2 fold. 1st, i noted location before dis-assy and 2nd assembled by Dyna instructions. (had to locate magnetic portion by hand as not obvious by diameter) regardless.. is the best I have. luck g
- jzanutto
21 Apr 2009 21:24
what grease did you use?
- OnkelB
21 Apr 2009 22:24
Look at the points cam, there's a scribe mark on the outer end of it. Then look at the advancer body, you will see a small hole in the backplate. When installing the points cam,the scribe mark should point towards the hole.
77 KZ 650 B1, 82 GPz 1100 B2.
22 Apr 2009 01:34
When the 1/4 F mark aligns with case mark, cam lobe should be facing rear to open the points wired to the 1/4 coil.
Good Luck!
Good Luck!
- jzanutto
22 Apr 2009 05:57
thanks guys...... grease?
- Bluemeanie
22 Apr 2009 06:09
jzanutto wrote:
My FSM says to use a little oil on advancer unit but when I need grease I use synthetic brake lube.
- OnkelB
22 Apr 2009 06:53 - 22 Apr 2009 06:54
Just for further reference here's a pic of a KZ 650 advance unit showing the correct orientation of the points cam:
Last edit: 22 Apr 2009 06:54 by OnkelB.
- jzanutto
22 Apr 2009 07:12
thats a great picture, it should be helpful not just to me but others in the future
- timebomb33
22 Apr 2009 07:45
i use moly grease or some torco assembly lube or cam lube my self.
I THINK MY POWERBAND BROKE
