- Thank you received: 3
Dyna coil fabrication
- hardr0ck68
- Who put the what in the where?
22 Apr 2009 14:07 #284107
by hardr0ck68
1977 kz650 c1
bought it because I was told it would never run again...I like to prove people wrong.
Replied by hardr0ck68 on topic Dyna coil fabrication
I cut up a black ball point pen to use as a spacer.
Err, I mean I had a machine shop in Japan source some rare period correct nylon stock.... they turn it down with tooling imported from France. The finished product was carried to me by a samurai. Total cost was less than 1,000.
1977 kz650 c1
- OnkelB
- Thank you received: 80
- brianpclarke
23 Apr 2009 18:33 #284571
by brianpclarke
-Brian
1977 KZ650C
1976 Kz900 LTD
Replied by brianpclarke on topic Dyna coil fabrication
UP and RUNNING! Thanks for all the help guys...
Here is a pic from my first ride, up in Park City Utah
-Brian
1977 KZ650C
1976 Kz900 LTD
- brianpclarke
23 Apr 2009 19:38 #284600
by brianpclarke
-Brian
1977 KZ650C
1976 Kz900 LTD
-Brian
1977 KZ650C
1976 Kz900 LTD
- timebomb33
- Thank you received: 10
23 Apr 2009 19:44 #284605
by timebomb33
I THINK MY POWERBAND BROKE
Replied by timebomb33 on topic Dyna coil fabrication
good to see you up and mobile how does it feel that first ride and hows the bike running.
- brianpclarke
23 Apr 2009 20:14 #284623
by brianpclarke
-Brian
1977 KZ650C
1976 Kz900 LTD
After 6x RPM's I was screaming! I am pissed I didnt buy this bike years ago. The highlight had to be a suzuki crotch rocket who thought he could take me... Once I hit 2nd, he had no chance!
Got some kinks to figure out... the speedometer went out on me when I was riding half way through the day, and the steering wobbles pretty bad, seemes especially bad on right hand turns (steering bearings??). The engine also has a little rattle, which I havent pinpointed. I need to check the shims and do some more maintenance. Weather forecast: 9 days of snow/rain/cold weather... aka: a chance for me to get all this squared away.
-Brian
1977 KZ650C
1976 Kz900 LTD
- timebomb33
23 Apr 2009 20:23 #284629
by timebomb33
the steering could be from misadusted shocks check to see if the pre load adjusters are the same on both shocks or improperly adjusted steering head bearings or bad ones or it could be from tire pressures or possibly swingarm bushing wear. see lots of things can cause the same sort of symptoms but nice to hear it goes hard. the speedo cables if not lubed properly can twist off inthe housing also one other thing to look at with your wobble problem might be wheel bearings give them a shake and see how they feel.
