engine cut off
- wizardofoz
engine cut off
19 Apr 2009 20:02
Hi, bike 1983 gt(kz) 550 shaft.
the neutral switch fine, kick stand switch fine, but I have to pull in the clutch lever for the motor to turn, what am I missing? Wiz.
- gane
Re: engine cut off
19 Apr 2009 20:25
Possibly nothing. looking at my Kz1000 manual, under Mint. electrical, clutch switch provides power after ign sw/fuse/kill sw.to starter sol. G
[img][/img] 1977 KZ1000A1
- MFolks
Re: engine cut off
19 Apr 2009 20:32
You can bypass the clutch switch by tracing back the wiring into the headlight housing. Splice the wires together and you won't have to pull in the clutch to start it(this was an early safety feature on the 80's bikes).
- wizardofoz
Re: engine cut off
19 Apr 2009 23:30
On my XJ (wash my mouth out) you pull the clutch to start only if in gear, but if the GT is as nature intended, I'm sweet, Thanks, Wiz.
