crazy thing
  • Darkangel
  • Darkangel's Avatar Topic Author
crazy thing
13 Apr 2009 07:01
#281337
Why does my guage lights and my running lights come on when my key is turned to the P (arking).
_________________________________________
1983 Kawasaki KZ 1100 A2 - streetfighter
Re: crazy thing
13 Apr 2009 07:14
#281338
One reason is better visibility of the bike by other traffic if parked at night on side of road.
Good Luck! :)
  • Darkangel
Re: crazy thing
13 Apr 2009 10:17
#281375
Ok...I know why the lights come on...that's obvious...I am wondering why dont they just come on when the key is in on..Because...other than that...I have no running lights.
  • MFolks
  • MFolks's Avatar
Re: crazy thing
13 Apr 2009 10:56
#281387
The bike may have what is called a "Reserve Lighting Circuit" This turns on the headlight(and maybe the running lights)after the engine starts. It also functions to provide a light to get home at night if the low beam burns out by turning on the high beam at reduced voltage.
Re: crazy thing
13 Apr 2009 11:09
#281391
If not already done, could likely find an oem wiring diagram by using the Filebase sub-menu under KZ Information located in the green ribbon at top of screen. Navigate to year, then model, and download diagram.
Good Luck! :)
  • bountyhunter
  • bountyhunter's Avatar
Re: crazy thing
13 Apr 2009 15:27
#281443
Soundls like somebody installed an aftermarket ignition switch assembly. That's what happened on mine when I had to get a new switch. It plugged into the harness but did not make the correct connections.
