Turn signals to LEDs
- superman960000
03 Mar 2006 14:43
Want to change turn signals to LEDs Suggestions or has any one already done a switch to theirs.
- BSKZ650
Re: Turn signals to LEDs
03 Mar 2006 16:38
there are some lights that plug in, 1157, bulb to led type. only problem is they dont reduce the power draw.
77 ltd1000, current rider
76 kz900, just waiting
- Biquetoast
- King Jeremy The Wicked
03 Mar 2006 16:47
superman960000 wrote:
Yep! This is a common thing. Just get rid of the flasher unit, and get a "heavy-duty" (electronic instead of analog) flasher from the auto parts store.
I got my rear 1156s and front 1157s from some online source (eBay or something).
Remember that most LEDs are only bright when looking straight-on, so you may be disappointed since they don't light the stock fixture as well. Still glad I did it though.
If you want to replace the brake/tail light, make sure you get a really good one. I prefer Radiantz from Custom Dynamics .
(1.) '75/'76 KZ400D - Sold
(4.) '75 KZ400D - Sold
kz750twins.com
kz750twins.com
- steell
03 Mar 2006 17:23
BSKZ650 wrote:
First time I have heard of this.
Quote from the website linked above:
AFAIK there are two advantages to using LED lights, they last longer and draw less power, and you are saying one of those is wrong.
Can you substantiate your statement with links?
5) Why do LEDs turn signals require the addition of a load equalizer or a non-load dependant flasher?
The turn signal unit or flasher is load dependent, it needs a certain amount of current to function. Many bikes are designed to flash at a faster rate if a bulb is burned out. Since LEDs draw much less current, your flasher unit may act as if a bulb is out and flash at the faster rate.
- loudhvx
03 Mar 2006 18:19
the bright filament in an 1157 bulb uses 2 amps. You would need a minimum of about 50 to 100 LEDs to use up that much current. If they are hooked up correctly, you could light up 500 LED's with 2 amps at 12 volts.
Post edited by: loudhvx, at: 2006/03/03 21:20
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
- Vter Bob
04 Mar 2006 15:17
I have converted all my turn signals to LED style using "Tower" type LED's I found from this company:
autolumination.com/otherleds.htm
I am very happy with these bulbs so far as they are not as directional as other 1157 type replacement bulbs. You do definately nned to change to an electronic flasher unit. Usually around $6 at any auto parts store or WallyWorld even.
Georgia, Vermont
1981 KZ550 LTD
1982 KZ1000 LTD
1999 ZG1000 Concours
Greetings from the Peoples Republic of Vermont, home of Ethan Allen, 2 American Presidents, a socialist US Senator and.....Homer & Bart Simpson
1981 KZ550 LTD
1982 KZ1000 LTD
