led replacement for 1157
  • riverroad
  • riverroad's Avatar Topic Author
  • 1980 1000LTD B4
07 Apr 2009 10:49
#279185
I bought some cool little turn signals last year that use these small amber 1157 type bulbs.
I like them but they keep burning out. I have them shock mounted on rubber, but I have them mounted where my side reflectors used to go, so they still get considerable engine vibration.
This is the bulb: www.jpcycles.com/productdetail.aspx?PID=...y&page=3&search=bulb
Can anyone recommend an LED replacement of similar dimensions that will fit?
And I guess I need a resister in series with it?
  • MFolks
  • MFolks's Avatar
Re: led replacement for 1157
07 Apr 2009 11:29
#279195
Here's some information on LED bulbs. The first is on the wedge base type used for instruments(speedo,tach
www.superbrightleds.com/mini-wedge.html
The second is on the twist base type(1156,1157)
www.superbrightleds.com/tail-brake-turn.html
Here's a cross index listing.
www.superbrightleds.com/bulb_cross.htm
  • bountyhunter
  • bountyhunter's Avatar
07 Apr 2009 11:31 - 07 Apr 2009 11:32
#279197
These are the ones I use:
www.superbrightleds.com/specs/115x-xLX3.htm
They are the only ones that are as bright as the standard incandescent bulbs.
As for:
The resistor would actually be in parallel to ground to increase the current draw, but that's a shameful waste of power. Better to buy a solid state flasher unit which will work with LEDs.
Last edit: 07 Apr 2009 11:32 by bountyhunter.
  • riverroad
  • 1980 1000LTD B4
07 Apr 2009 12:42
#279214
Wow, nice site! Looks like they have what I need.
Thanks guys!
bountyhunter, those Lexions look like they "might" fit, but the heat sinks are kinda large. Do you remember if yours looked like the heat sinks could be ground down a little on the edges?
I do want bright signals.
  • bountyhunter
07 Apr 2009 22:21
#279367
Thanks guys!
The heat sinks are solid aluminum and the LEd is attached to it so I think grinding might be risky. It could damage the thing. The LED die is attached to the heatsink.
  • PLUMMEN
  • PLUMMEN's Avatar
07 Apr 2009 22:24
#279368
wow,i didnt realize you could use same sockets B)
  • riverroad
  • 1980 1000LTD B4
08 Apr 2009 11:37
#279540
Bountyhunter, do those super bright LEDs operate just like an 1157 duel filament bulb, with signal AND running lights?
  • bountyhunter
08 Apr 2009 13:59
#279597
They operate exactly the same as a dual filament bulb, have a separate contact on the bottom for bright or dim "filament". But, there is only one LED so they use a different series resistor (inside the base) to make the LED brighter or dimmer depending on which of the two bottom contacts gets power. That way it looks like a dual brightness bulb just like a 1157.
  • riverroad
  • 1980 1000LTD B4
09 Apr 2009 04:22
#279835
Ah so, thanks for clearing that up for me bounty hunter.
a series resister. I was having a hard time figuring out how they run two circuits through one led.
Thanks!
  • School Teacher
  • School Teacher's Avatar
10 Apr 2009 13:35
#280320
they have these at most local auto stores
1976 kz900 in parts but will be going some day soon
1980 kz1000G1
1976 kz900 parts bike
1979 kz1000 shaftie parts bike
1978 kz1000 33mm smoothies 1075 kit
Troutdale Oregon USA
