KZ440 Ignition Points? Electronic?
- sean5775
03 Apr 2009 07:22 - 03 Apr 2009 07:26 #278014
by sean5775
1972 Kawasaki H2-750 Triple Mach IV
1976 Kawasaki KZ900 A4
1981 Kawasaki KZ440 LTD
1981 Kawasaki KZ750LTD-4
1983 Suzuki GS650 Tempter
1981 Yamaha Virago XV920
KZ440 Ignition Points? Electronic? was created by sean5775
I have this 1981 KZ440 I am working on and just wondering what anyone could tell me about this ignition system. I know the pic looks rough but I want to change a few things. I guess you have to click this little blue square here to see the pic. It doesn't seem to be working properly for me.
Last edit: 03 Apr 2009 07:26 by sean5775.
- loudhvx
- Thank you received: 1616
03 Apr 2009 08:17 #278028
by loudhvx
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Replied by loudhvx on topic KZ440 Ignition Points? Electronic?
Well it looks a little rusty. The part you are showing is the pickup and advancer mechanism for the stock kawasaki electronic ignition. The little black cube sends a signal to the igniter box which controls the ignition coil to make the spark.
What about it isn't working? With it being that rusty, I would guess the advance may no not be working. If you grab the rotor, it should rotate a few degrees and spring back on its own. If not, you have to take it apart and lube it.
Here's the photo.
Here's the photo.
1981 KZ550 D1 gpz.
Other links.
