KZ1000B2 left switchgear
- NAFWAM
01 Apr 2009 18:06
I had to pull the switchgear wiring out of the bars to replace them but on the left side there was little to pull with and using force on 30 year old wiring caused a few of them to break off at the soldered joint.
I wonder if anyone has a spare switchgear for the left that they can take a look inside. I need to know where the Orange/Green, Green and Grey wires go so I can solder them back on. I am thinking the grey to the horn switch to make a pair with the black/grey and the remaining 2 to the circuit board in the bottom of the pod for the hazards. BUT which one goes forward on that board and which at the back. There are 3 contacts as you look in. The one furthest forward is dirty and doesnt look like anything has connected to it, so which way round do the Or/Gn and Gn go? can anyone help with that?
- gane
Re: KZ1000B2 left switchgear
01 Apr 2009 19:14
N, the schematic in the service manual shows color codes and connections of individual switches within assy. below actual wiring diagaram. hope this helps. G
[img][/img] 1977 KZ1000A1
- NAFWAM
01 Apr 2009 20:06
G - I did take a look at the schematic and it shows Or/Gn, Gn and slate at the hazard switch. Presume slate is the grey wire so thats all the loose ones. I assumed there was one to go to the horn as there is only a Blk/Wh on that and the front is marked horn/pass.
I think I still need to see a picture as I dont know which colour wire goes to which of the 3 pins on the hazard switch and could do with a reminder of how the retaining plates are fastened.
I did take a photo as it is now though It needs to be seen in a higher resolution than I can probably post on here. Wishing i had stopped to take one before i pulled on the wires to get them started !
- gane
02 Apr 2009 21:49
N looking at my Kz1000 schematic. interupted power from hazard flasher enters hazard sw on or/green, and enters t/s wiring on slate and green wires at switch simotaiously when depressed. Bk/white is hot tru horn and button provides ground. luck G
- NAFWAM
- kano
- Not Another Bloody Limey!
03 Apr 2009 06:00Please Log in or Create an account to join the conversation.
- NAFWAM
04 Apr 2009 09:54
Yeah it does. thanks Kano Think Ive got the order right now so will get the soldering iron out and give it a go and post back to let you and G know if it proves successful. Cheers
