New Plug Wires w/ Dyna Coils?
- Jack
31 Mar 2009 11:32 - 31 Mar 2009 11:33
About to replace the old coils with new Dyna 3.0 ohm green and plug wires etc. on my MKll with Dyna S ignition. What plug wires do you guys use or recommend with this combo ?
79 KZ 1075 MKll
79 KZ 1500 MKll dragbike
Gone but not forgotten:
3 X 73 Z1's
1 X 74 Z1A
1 X 75 Z1B
3 X 73 Z1's
1 X 74 Z1A
1 X 75 Z1B
Last edit: 31 Mar 2009 11:33 by Jack.
- cruspeed
Re: New Plug Wires w/ Dyna Coils?
31 Mar 2009 11:52
Before I completely dissasembled my bike I did the same thing, I used 7mm copper core wires because you don't have to worry about any other electrical interference. If you go and use some sort or aftermarket electrical tacks or speedo's that don't run on cables you will want to choose supression. If you run supression wires with resistor plugs you run a good chance of damaging your ignition system.
Someone correct me if I am wrong plz.
78 KZ1000 project X 2
- T_Dub
31 Mar 2009 11:55
So when I put an electric tach on the bike I have to switch to suppression wires? Bummer.
1977 KZ650B1
-810cc
-Cavanaugh Racing Head
-Mikuni RS34's
-GPR Muffler
-810cc
-Mikuni RS34's
-GPR Muffler
- cruspeed
31 Mar 2009 12:01
You don't have too, but it may interfer with the tacks ability to count sparks. I have an aftermarket koso gauge everything and copper wires, I was just sure to run the gauge wires far away from the spark plug wires and everything worked fine.
- T_Dub
31 Mar 2009 12:08
Alrighty, I'll make sure I make the distance as far as possible.
1977 KZ650B1
-810cc
-Mikuni RS34's
-GPR Muffler
-810cc
-Mikuni RS34's
-GPR Muffler
- OnkelB
31 Mar 2009 12:20
Jack, I'd get a set of Dyna wires - they fit the coils and are easy to install, $17 at Z1E:
www.z1enterprises.com/detail.aspx?ID=209
Been running that exact setup (Dyna S, Dyna 3 ohm coils and Dyna wires) on my 650 for like 3 years now, no problems at all.
You can get Dyna suppression wires too if that's what you need.
77 KZ 650 B1, 82 GPz 1100 B2.
- timebomb33
31 Mar 2009 23:32
ive got dyna wires on my 4000sp ignition suppression core wires,i have accel 8.8 suppression core on my dynas with drl 400 two-step on my little bike and i have a set of taylor wires on mystreet bike with dyna111 and drl-200 high end rev limiter suppression core as well.
I THINK MY POWERBAND BROKE
- GalwayZ
01 Apr 2009 02:07
Jack.
I have a B1 650 - i fitted dyna s pickups/ dyna coils and dyna wires - all from z1 - big improvement straight away.
Check your coil voltage too - if its low - try the coil mod as recommended by wiredgeorge.
- Jack
01 Apr 2009 06:45
Thanks guys, Dyna wires it is...
79 KZ 1075 MKll
3 X 73 Z1's
1 X 74 Z1A
1 X 75 Z1B
3 X 73 Z1's
1 X 74 Z1A
1 X 75 Z1B
