headlight wattage on kz1000
- cruspeed
30 Mar 2009 20:12 #276917
by cruspeed
78 KZ1000 project X 2
headlight wattage on kz1000 was created by cruspeed
Anyone know the stock low and high beam headlight wattage draw? Mocking up the dual headlights and don't want to strain the charging system.
- MFolks
- Thank you received: 540
30 Mar 2009 20:32 #276937
by MFolks
Replied by MFolks on topic headlight wattage on kz1000
I believe it's 55 Watts for low and 60-65 for high beam(could be wrong).
- bountyhunter
- Thank you received: 337
30 Mar 2009 21:52 #276954
by bountyhunter
Replied by bountyhunter on topic headlight wattage on kz1000
If it is one of the old style 7" round units, the low beam was typically around 35 - 40W and the high beam is about 55 - 60W.
- cruspeed
31 Mar 2009 08:24 #277002
by cruspeed
Replied by cruspeed on topic headlight wattage on kz1000
okay and thanks, I can get the 35w H3 low beam and 55w high beam from the auto store and put them in with the dual lights and be okay. Run them off a 5 pole relay so it's either one or the other when I throw the switch from low to high. I was thinking 35 was okay for low but I didn't think that it would be enough light for high beam.
