Rear turn signals not working
- Darryl
30 Mar 2009 17:44
Hi, the rear signals on my bike don't work. They are the single wire type. The front signals work fine they have two wires going to each light.
Do the rear lights not need 2 wires going to each light?
Help
Help
1983 Kawasaki KZ1100 D2 Spectre
- MFolks
Re: Rear turn signals not working
30 Mar 2009 17:56
The front lights on these 80's bikes have three wires going to each light, a running light wire, a turn signal wire, and a ground wire.
The rear lights have a turn signal wire, and a ground wire.
Some guys install another set of front turn signal lights to get rear running lights with additional wiring spliced in.
I'd check the ground wires and the turn signal wires for corrosion in the connectors.Check the condition of the bulbs as vibration can break the filiments.
- Darryl
30 Mar 2009 18:17
There is only one wire going into each of the rear lights
- MFolks
30 Mar 2009 18:25
Are they stock lights that came with the bike or are they a custom add on? The stock lights should have two wires, one for the signal circuit and the other for the ground as most lights are vibration resistant mounted with a rubber bushing.
- Darryl
30 Mar 2009 18:44
Yes they are stock as far as I can tell and inside the housing is only one wire soldered to the connector were you push the bulb into.
- MFolks
30 Mar 2009 18:51
Have they suddenly quit working? Try adding a ground wire from the frame to the light housing and then try the turn signal function. The lights again should have two wires going to the turn signals.
- Darryl
- timebomb33
30 Mar 2009 19:14
the body of the signal light is the ground there is a ground wire attached to wear the signal light stalk mounts in the frame.
I THINK MY POWERBAND BROKE
- Darryl
30 Mar 2009 20:01
Seems the stem is the ground but the rubber mounts get in the way so I attached a copper wire to the stem then to a near by bolt.
I'm now ready to take it to get a safety certification.
Thanks guys for the help.
