Dyna S troubles, thoughts?
- anarki650
Re: Dyna S troubles, thoughts?
05 Apr 2009 15:57
N0NB wrote:
Man, I've got NO idea what you just said Nate!!! Maybe a schematic to help out those of us who are electrically ignorant? :silly:
Jeff.Saunders wrote:A bad regulator will allow very high voltage to spike the Dyna-S. 17v-18v or more is not unusual when a regulator fails.
Hmmm, perhaps a 15V zener diode across the power lead to the Dyna S might offer good protection.
09 Kawasaki ER6n
77 kz650b1 cafe rebirth project
"Being shot out of a cannon will always be better than being squeezed out of a tube, that's why God made fast motorcycles..."
Dr. Hunter S. Thompson
Omaha NE
Omaha NE
- gane
05 Apr 2009 16:18 - 05 Apr 2009 16:19
A, A reference to an antiquated form of voltage/current regulation which was used on 6 & 12 volt positive grounded (primarily) English machines abandoned most probably while most here were in diapers, IE a pun. G
[img][/img] 1977 KZ1000A1
Last edit: 05 Apr 2009 16:19 by gane.
- Old Man Rock
05 Apr 2009 16:49
A 15Vdc zener diode will keep the voltage at 15Vdc as long as the charging circuit is at or greater than 15Vdc... Think of it as a voltage regulator...
The downfall of that concept is if you do have a problem with your charging circuit, you won't know it while that zener is installed....
Personally, FIX the problem with the charging circuit for as it was designed for there's more than the ignition circuitry counting on that being correct...
And yes, I do have a degree in electronics... :laugh:
OMR
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- anarki650
05 Apr 2009 16:52
My charging system on the 650 is tip top. NOS stator, replaced the reg and rec with units from
www.oregonmotorcycleparts.com
. I charge at 13.7 at idle and 14.6 at anything above 2500 rpm. So long as that system stays within spec I shouldn't have to worry about frying a planned Dyna S then should I?
09 Kawasaki ER6n
Omaha NE
Omaha NE
- loudhvx
06 Apr 2009 18:04 - 06 Apr 2009 18:37
N0NB wrote:
Won't work or at least not for more than a second. A typical 15v, 1W Zener is only rated to sink about 66 milliamps before it goes up in smoke. The Lucas regulators used this laughable method of regulation and we know how well those worked (and those were very high wattage Zeners with massive heatsinks).
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
Last edit: 06 Apr 2009 18:37 by loudhvx.
