Fix for inop front brake light.
  • coppertales
  • coppertales's Avatar Topic Author
30 Mar 2009 10:54
#276758
I have two 82 KZ1100D bikes that the front brake lever light never worked. This weekend I decided to tackle the project. I removed the seat, tank, and right side cover. I unplugged the wires from the brake switch and checked the switch with an ohm meter. Switch is ok. I then followed the wires from the switch back through the wire harness. The right handlebar controller ends at a 6 pin connector under the gas tank. I unplugged the connector and ohm checked the blue and brown wire to the brake switch. They checked ok. I then unplugged the rear brake switch and ohm checked the blue and brown wires from the 6 pin connector to the pigtales that go to the rear brake switch. The blue wire was ok but the brown wire was open, aka broken. I then cut the brown wire on the front brake swich side of the 6 pin connector and ran a new wire to the brown pigtale that plugs into the rear brake switch. I used a new wire because trying to disassemble the harness while on the bike would be very difficult to do. Anyway, I reconnected everything I had disconnected and turned on the ignition switch. I now have front and rear brake lights. The problem with my other bike was identical so the fix there was easy seeing I knew what to look for. I know the wiring is not the same with all these KZ bikes but it my post may help anyone with this problem get started in the right direction.....chris
1982 KZ1100 A2
1982 1100 SPECTRE
1982 1100 SPECTRE
  • greg9299
  • greg9299's Avatar
Re: Fix for inop front brake light.
15 Apr 2015 10:03
#668061
Chris: Thanks for the post. I also have an 82 KZ1100D with the same issue. Your solution worked great and saved a lot of time and effort uncovering wiring and routing. Thanks again.
Greg
  • MFolks
  • MFolks's Avatar
15 Apr 2015 15:15
#668096
The factory soldering jobs leave a lot to be desired, and are starting to fail on the older bikes. I'd take the time to open up the left and right handlebar switch "Pods", and check the solder joints. If you need, I've got a repair procedure, just ask....
