Turn Signal Stems
- T_Dub
Turn Signal Stems
24 Mar 2009 11:51
I'd liek to get 35mm turn signal stems for my 650. Will KZ1000 stems work on a 650?
1977 KZ650B1
-810cc
-Cavanaugh Racing Head
-Mikuni RS34's
-GPR Muffler
-810cc
-Mikuni RS34's
-GPR Muffler
- MFolks
Re: Turn Signal Stems
24 Mar 2009 12:03
I'd imagine they would, as Kawasaki tried to make many models parts interchangeable to lower costs.
- T_Dub
24 Mar 2009 12:15
Thats what I think too, but the part numbers dont match up so I want to make sure. I'll probably end up buying them anyways, and make tehm fit if I have to.
1977 KZ650B1
-810cc
-Mikuni RS34's
-GPR Muffler
-810cc
-Mikuni RS34's
-GPR Muffler
- RonKZ650
24 Mar 2009 12:30 - 24 Mar 2009 12:31
I've used them interchangably over the years. The difference is the base of the KZ1000 stem is more heavy, and molded as part of the stem, where the KZ650 stem uses just more or less a molded fender washer. The 650 gets bent real easy, where the KZ1000s dont. If there's a difference in length, it's not noticable. I measured two and the difference *may* be 1mm.
Last edit: 24 Mar 2009 12:31 by RonKZ650.
- T_Dub
24 Mar 2009 13:24
Cool, thanks, I'll be using them then. I noticed that about the base, seems much more robust on the 1000.
1977 KZ650B1
-810cc
-Mikuni RS34's
-GPR Muffler
-810cc
-Mikuni RS34's
-GPR Muffler
- KawiConvert
24 Mar 2009 19:37
I used stems from a cb400 on my 650. You just need a 10mm stem as most turn signals use a standard mount.
1978 KZ650 D1 ~ Carb jetting: 107.5 & 20 & 4th groove with pods and 4-1 Exhaust
- rstnick
25 Mar 2009 18:34
I've also used 1000 stems on my 650 in the past.
Their a dirrect fit.
Some stems do have a thinner hole down the center if they're designed for two wire signals, and need to be drilled larger if your B model front signals have 3 wires running through them.
The 3 wire signals are also running lights. C model 650 have these on the front. You can also put 3 wire front signals from the front onto the back and run the 3rd wire to the back to give you 4 running lights, all around.
Makes for added visabilty for other drivers to see you better at night, but may be illegal in some areas.
I do miss having 4 running lights as I've since put other signals on over the years.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
