charging problem
- RIBSNFRIES
charging problem
22 Mar 2009 17:04
kz1000j just need to know i have between 14 n 14 n half volts at idle and mabey goes higher but not over 15 but dumb questions is voltage rectifier combo get a little hot to the touch does this sound normal thanks:dry:
- keith1
Re: charging problem
22 Mar 2009 17:29
RIBSNFRIES wrote:
by no means an electrical guy, but 14.5 should be max at about 4k.....hopefully the more knowledgable will respond......
- timebomb33
22 Mar 2009 17:32
check the output at around 3000 rpm and see what you have then 14-14.5 at idle seems high and the rectifier/regulator will get warm that is why it is made from alloy and has cooling fins max out-put shouldn't be much higher than 14.5 volts
I THINK MY POWERBAND BROKE
- hoghaterkaw
22 Mar 2009 20:23
RIBSNFRIES wrote:
the reg/rec will feel warm to the touch but not uncomfortable. for now you should go thru all of the wiring connects and do a clean up. fuse box, light sockets, et all. if you see a plastic connect cover that is brown or black, that connect is dirty/corroded.
- MFolks
22 Mar 2009 20:37
I use a very good electrical contact cleaner/preservative made by Caig Labs in San Diego called De-oxit. Their website is
www.deoxit.com
Get some 400-600 grit sand paper,a brass bristle brush and some time to kill as cleaning the electrical connectors can consume some time for a good job.For the female "Bullet" connectors I find a pipe cleaner sprayed with De-oxit will remove the green crud of corrosion.
Check the fuses and fuse clips for corrosion too as they are important in voltage regulation.
