Battery Acid Disposal
- wireman
Re: Battery Acid Disposal
02 Mar 2006 16:42
use portland cement to clean up oil grease stains on concrete.rub it in like floordry and sweep the rest across the floor it will look like new concrete!:whistle:
- ran429
- Master of FREE rides!
02 Mar 2006 18:56
Duck wrote:
I think you are speaking of Muratic acid ?
Sulfuric acid is the most pleasant to use for cleaning cement off brick and for etching concrete. If you can't find any smaller quantity, perhaps you could spiff things up around the house with the leftovers...It's also handy for cleaning up quarry or other porous tiles after grouting.
-Duck
- ran429
02 Mar 2006 18:57
wireman wrote:
So your saying that your pipe threader made a horrible mess on the new cement and you found a way to actually cover it?
Post edited by: ran429, at: 2006/03/02 21:58
- wireman
02 Mar 2006 19:28
yes i did,that bag just happened to rip in the same place in the same place the truck leaked in that driveway!:whistle: concrete finisher taught me that trick,it actually works:woohoo:
- Duck
- e vica na i sau na ga
- Duck
03 Mar 2006 03:34
Muratic is HCl and NASTY compared to H(2)SO(4) for cleaning brick/tile. It costs a bit less around here. It fumes a lot more and fumes are more irritating. I use Muratic for cleaning scale off steel, outdoors, wear rubber, stay upwind. -Duck
- RomSpaceKnight
03 Mar 2006 09:13
I'm with savedrider. Are you sure you need acid not distilled water?
- Shoey949
03 Mar 2006 12:46
Well here's the deal, it's an embarrasing story. I first bought the acid last spring to fill two motorcycle batteries, everything went fine but as you can imagine I had a lot of battery acid left,so I wrapped it up in a paper bag and left it outside. Well it spent a whole year outside including a michigan winter. Then a couple of weeks ago I purchased a brand new battery for a project bike I've been working on. I filled the battery with the old acid, each cell between the high and low marks as it should be. It charged fine. I was working on the lights and starter on this bike, but wasn't actually running it so the battery wasn't getting any charge. So eventually its power drained, and went to recharge it and it won't. I can even get enough voltage in the battery to turn over the starter. So my thought was the acid had gone bad, I don't know what else to do. I don't have a hydrometer to check the battery, but I may be doing so soon. I was just thinking of draining all the old acid out and refilling it.
Thanks,
Nate
Thanks,
Nate
'83 GPz550H2 w/'81 GPz 550D1 engine
Dynojet Stage 3 kit, MAC 4-1, UNI Pods, DYNA coils and plug wires, WG ignition mod
Grand Rapids, MI
Grand Rapids, MI
- savedrider
- 1975 Z1-B 900
03 Mar 2006 19:49
Hmmmmm Nate, I'm no expert here, but it is possible that your old acid was bad. Maybe water got inside and diluted it?
At any rate, I think you might be screwed if you try to drain and refill. It is the initial chemical reaction that occurs when adding acid that is important. By possibly adding bad acid to a new battery I think you might have missed your opportunity to properly setup the battery. Did the battery get warm, bubble, and gas real good when you added acid? It should, it's part of the reaction.
Acid is cheap enough though, so you could always pick some up and try to refill and charge it. Make sure you use a 1amp or less charger. I just picked up a real nice Battery Tender that charges at 750mah.
Get right or get left! <*{{{><
