Fireing order
  • RIBSNFRIES
  • RIBSNFRIES's Avatar Topic Author
Fireing order
19 Mar 2009 15:43
#273510
BOOK IS 1243FIRES ORDER KZ 1000J SO ONE COIL FIRES 1 4 ONE FIRES 2 3 I HAVE 1 ON OUTSIDE AND4 ON OUTSIDE 2 AND 3 IN MIDDLE SO HOW DO I PLUG WIRES IN THANKS:S :S
  • ltdrider
  • ltdrider's Avatar
Re: Fireing order
19 Mar 2009 16:15
#273519
The spark plugs are numbered 1, 2, 3, and 4, left to right, as you sit on the bike and look at the plugs. #1 is on the left side, and #4 is on the right side.
So the plug wires from plug # 1 and plug #4 run to the 1-4 coil, and the plug wires from plugs #2 & #3 run to the 2-3 coil. Which coil is 1-4 and which one is 2-3 depends on how they're wired from the timing plate where your points are (I think).
'76 KZ900 LTD (Blaze)
'96 Voyager XII (Dark Star)
Greensboro, NC
