spark plug wires different on each side?
- burkmanofgod
- 1981 KZ750H2
16 Mar 2009 19:57
I almost have this bike going but something strange came up. I got some replacement plug wires and when I started to change them I noticed that the wires on the right side had twist on caps on the coils, which I like the looks of, but the left side doesn't have the twist on caps and appear to be stuck in place.
Right Side with twist on caps
Left side with stuck in wires
Any help on getting the left side wires out without breaking something would be great.
1981 Kawasaki 750 LTD
2006 Honda Shadow 1100 Spirit
- MFolks
Re: spark plug wires different on each side?
16 Mar 2009 20:03
The previous owner (P.O.) may have switched out a bad coil or two in the past. I don't know what your bike came with so can't recommend any one manufacturer of coils.
Try asking at www.z1enterprises.com they might be able to help.
- burkmanofgod
- 1981 KZ750H2
16 Mar 2009 20:03
- burkmanofgod
- 1981 KZ750H2
16 Mar 2009 20:06 - 16 Mar 2009 20:20
Sorry I didn't include that info. The Bike is a 1981 KZ750 H2 with the four cylinder engine.
Last edit: 16 Mar 2009 20:20 by burkmanofgod.
- MFolks
16 Mar 2009 20:38
The left coil does have the molded in sparkplug wires. You might be able tomget the NGK splice kit if you plan on keeping the coil.
- burkmanofgod
- 1981 KZ750H2
16 Mar 2009 20:43
Thanks for the help. I just found the splice kit on Z1 and they were much cheaper than a new coil. I was thinking I should splice up close to the coil so as too remove as much old wire as possible.
- Old Man Rock
17 Mar 2009 04:46
Quick question... Have you Ohmed out the coils?
If different, you may just want to upgrade your coils so you have an even spark....
Just a thought...
OMR
Just a thought...
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- burkmanofgod
- 1981 KZ750H2
17 Mar 2009 18:27
What is Ohmed out the coils? Can you discribe this to me?
- Old Man Rock
17 Mar 2009 18:59 - 17 Mar 2009 19:09
Resistance measurements of your coils using an Ohmeter/ Volt meter/DVM with resistance measurement capabilties....
The procedure is easy to accomplish, should be in your service manual... Basically you'll be doing the following...
Primary and Secondary winding measurements...
Don't know your system but for the KZ900/1000 series primary should fall between 3.2 & 3.8 ohms on the primaries.... ~ 30K ohms on the secondaries...
EDIT: Here's out of my KZ 900 manual....
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
Last edit: 17 Mar 2009 19:09 by Old Man Rock.
- burkmanofgod
- 1981 KZ750H2
17 Mar 2009 19:06
Thanks I'll do some reading on it and see what I can find out.
