no start & extra connector(
  • da_wun
  • da_wun's Avatar Topic Author
15 Mar 2009 10:27 - 16 Mar 2009 18:19
#272129
Hey everyone,
So i finally had some time to re-assemble the bike (1980 KZ750H) that i got about a month ago (P.O. disassembled it to have it repainted, but ended up buying a new bike).
I started connecting everything with high hopes, but ended up with an extra connector ?!?! It comes off the main wiring harness.
It's a 4 pin female connector, with a red, green, black and yellow/black wires. I have no clue where it goes, and there is no extra connector :S.
On another note, the bike doesn't even turn over. I did pull in the clutch to start it. There's no nothing. P.O. said that it was running last fall, so am guessing that all the components should be fine, maybe i didn't wire everything correctly.
Thanks for the help!
Bare Metal 1980 KZ750H (no longer burgundy)
West-Island, Montreal
Last edit: 16 Mar 2009 18:19 by da_wun.
  • timebomb33
  • timebomb33's Avatar
Re: no start & extra connector ?!?!?
15 Mar 2009 11:05
#272139
that looks like the trigger wire from the ignition to the ignition box if i'm not mistaken where is your ignition box and is it hooked up and is your plate hooked up also.
I THINK MY POWERBAND BROKE
  • da_wun
15 Mar 2009 11:39 - 15 Mar 2009 11:47
#272149
oh man!
thanks, it was the connector for the ignitor.
The male end was hidden behind another wire. . . argh...
What did u mean by connecting it to the "plate" though ?
I connected it, but still no start. . . . .
edit...
The headlights or turn signals don't work either for some reason. When I received it, I connected to battery to see if it was working, and the headlights and neutral light worked. But now, only the neutral light works.
Last edit: 15 Mar 2009 11:47 by da_wun.
  • MFolks
  • MFolks's Avatar
15 Mar 2009 12:38
#272154
I'd check the main fuse block for faulty or bad fuses and look at the fuse clips for corrosion.
The older glass tubed fuses can fail and look o.k. Remove them one at a time checking with either a continuity light of a multi meter set on OHMS.
I suspect the plug with the wires wind up going to the ignition coils somehow.
  • da_wun
15 Mar 2009 15:17
#272183
So ya, I only observed the fuses by eye, and not with a multimeter. I thought they were good, but when i checked the resistance, they were dead.
Switched em out, and now the engine turns over :cheer:
Just gotta put some gas in it. That'll have to wait for tomorrow.
Thanks a bunch!
  • roy-b-boy-b
  • roy-b-boy-b's Avatar
16 Mar 2009 04:48
#272300
Are you riding the bike yet? Roy
  • bill_wilcox100
  • bill_wilcox100's Avatar
16 Mar 2009 07:30
#272339
da_wun, welcome to the KZR Nation.
Strange to have another KZ650 member from Montreal. What area are you in? What colour is your bike?
Best of success. :)
PS
Remember to add your year, model and location to your signature to get the best replies. It's considered real friendly too.
Bill
1977 KZ650-B1 (Stock)
Upgrades:
- Dyna S Electronic Ignition (DS2-2)
- Dyna 3 Ohm Coils (DC1-1)
- Coil Repowering Mod
- Progressive Springs Front & Rear
- Saddlemen Seat Cover
- New Metallic Red Re-Paint & Repro Badges.
Montreal, Canada
  • da_wun
16 Mar 2009 17:51
#272515
Thanks !
It's actually a KZ750 =P....
And the P.O. repainted it, to a nice burgundy colour
(blah X.X)
And no, unfortunately it didn't fire up. She cranks now though, and the headlights are working. For some reason though, there has to be a connection with the electro-bracket (left side) and the frame, or else nothing works. I think there's a ground connection missing, but i can't find it.
I gotta check if there's a spark; haven't had the chance to really check anything. Exam and assignments due this week.
I'll only be able to work on her this weekend :(
Ryan
  • da_wun
02 Apr 2009 20:01
#277869
quick update.
she runs fine now. everything is connected.
installed new exhaust gaskets (old ones were like crud),
changed the flasher relays, flattened my seat,
flipped the handlebars... etc etc. . .
just need to get some insurance and start riding.
ciao! :pinch:
  • bill_wilcox100
02 Apr 2009 21:07
#277898
Good stuff... now we want pictures!
Best of success. :)
Upgrades:
Montreal, Canada
  • timebomb33
02 Apr 2009 21:10
#277900
what connection were you missing.
