Starter Removal - Case Cracking?
  • KAHruzer
  • KAHruzer's Avatar Topic Author
13 Mar 2009 08:35
#271576
1981 KZ550 LTD
STARTER REPLACEMENT/REBUILD
Wondered if someone can tell me if the case has to be cracked to remove/replace the starter on this 550?
...found this 550 locally and trying to decide if it's worth the trouble.
KZ750-H4 LTD 1983 Project
KZ400-B2 1979
  • Mark Wing
  • Mark Wing's Avatar
Re: Starter Removal - Case Cracking?
13 Mar 2009 08:42
#271578
Welcome. I don't think so. I'm a 650 guy but I think their pretty much the same.
Mark
Yorba Linda Cal.
  • KAHruzer
13 Mar 2009 08:47
#271581
Thanks Mark,
just now going to look at it, but that would be a stopper, I think.
KZ400-B2 1979
  • gorack
  • gorack's Avatar
13 Mar 2009 10:32
#271596
the 650/750 are about the same as 550, the starter is a easy fix no case cracking 4 bolts and a wire your done
  • MFolks
  • MFolks's Avatar
13 Mar 2009 10:52
#271600
There is a cover directly below the carbs on the engine that the starter is under.
Remove the two metric bolts(10MM I think).Disconnect the starter wiring and I believe you will have to remove the left side engine/stator cover to access the starter gearing.
Have a new gasket on hand as the old one will probably tear/stick on removal.
Rebuild stater kits are available. I'd try www.z1enterprises.com first.
