Newbie Needs Help!! Lots of it!!
- mox369
12 Mar 2009 18:10
Got a bike that doesn't run 83 KZ 1100 LTD, i was told that all id need to do is put the carbs on and id be good. I put a battery in it, carbs on, and new spark plugs, i dont have the gas tank on yet, i hit the start button with the key on(headlight turns on and it says its in neutral) and nothing happened. i tried looking at the spark plugs when i hit the starter and no spark. Please help, id like to get this bike running asap!! I dont know much about bikes, or the electrical systems, but i can follow wires.
I have put all new oil and coolant in already so i should be good on that stuff, i just wanna know it can fire up when i put gas into the system. Thank you guys for the help, i need it!!!
83 KZ 1100 Shaft Drive
- burkmanofgod
- 1981 KZ750H2
Re: Newbie Needs Help!! Lots of it!!
12 Mar 2009 18:14
It might be a safety that needs to be engaged. I know on my KZ750 it won't turn over unless the clutch lever is pulled.
1981 Kawasaki 750 LTD
2006 Honda Shadow 1100 Spirit
- gane
12 Mar 2009 18:14
quick try. pull in clutch lever. g
[img][/img] 1977 KZ1000A1
- Locozuna
12 Mar 2009 18:26
Kill Switch on the handlebars should be on run. Is it turning over? You won't see spark unless it's turning over.
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
"If you seek for Eldorado!"
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
- mox369
13 Mar 2009 00:56
lol im a lil drunk lol, started the weekend early, but anyway, i did try to pull in the clutch and it wouldnt do anything, also had the start on "Run" when i tried starting it, thanks for the help so far, any other suggestions? This is my first bike and first project but am exited for it to turn over, thanks for the help, any other suggestions woulb be awesome!!!
- Mcdroid
- Gone Kwackers
13 Mar 2009 01:32
mox369 wrote:
It is usually a simple answer so don't despair yet. However, I am curious what kind of 'coolant' you used for the bike?
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- mox369
13 Mar 2009 02:15
well i couldnt tell ya, ill prolly get yelled at for this, but there was a tiny radiator looking thing on the bike so i just took it to a shop and told them to fill it up, but i am tryin to do the rest on my own. Prolly should have found out what i needed on here first and just did it, but that was before i knew this site existed. Thanks, still need suggestions on gettin the bike started
- Mcdroid
- Gone Kwackers
13 Mar 2009 02:48
mox369 wrote:
Well, it is going to be a steep learning curve. If the shop took money for that then you need to get it refunded. That 'radiator' is an oil cooler that fills automatically when you add oil to the bike. The bike shop knew this. There is no separate 'cooling' system ...Kawasaki introduced that, in think, in 1985. Are you handy with a multimeter for checking your electronics? Never fear, other KZR members should chime in as the sun emerges.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- BSKZ650
13 Mar 2009 05:50
Mcdroid wrote:
well at least they didnt sell him blinker fluid:woohoo:
mox369 wrote:well i couldnt tell ya, ill prolly get yelled at for this, but there was a tiny radiator looking thing on the bike so i just took it to a shop and told them to fill it up, but i am tryin to do the rest on my own. Prolly should have found out what i needed on here first and just did it, but that was before i knew this site existed. Thanks, still need suggestions on gettin the bike started
77 ltd1000, current rider
76 kz900, just waiting
- Grantl
- KZRider is Da Bomb!!!
13 Mar 2009 06:53
Do you hear a clicking noise when you press the starter button? Does the headlight dim when you press the starter button? Is the motor turning over but you don't have spark at the plugs? or its not turning over at all?
1981 KZ1000 CSR
1983 KZ750 Project Bike
1990 550 Zephyr
1994 KZ1000 P
1990 550 Zephyr
1994 KZ1000 P
- gorack
13 Mar 2009 10:39
if the bike shop put coolant in the the oil cooler you better drain it and the oil, or you'll be really bumming when your motor is trashed, and i would post the name of the bike shop so nobody patronizes them ripping off people is not really cool
- mox369
13 Mar 2009 11:44
Oil cooler huh, that pisses me off, i just drained all the oil and put new oil in. The headlight does not dim, there is no clicking, and the motor is not turning over. What the hell have i gotten myself into lol. I dont have the name of the shop off hand, but ill post it on here later. The whole wiring harness seems to be intact so i dont know whats going on, and the shop said that they are a kawasaki dealer and there was never a manual made for my bike, that seems like bullshit, a manual would be extremely helpful right now i think. Its a 83 KZ 1100 LTD.
